no brakes
Old Mar 18, 2012 | 08:29 PM
farmboy99's Avatar
no brakes
when i hit my breaks my truck hops like no other. I put new pads rotors stablizer bar and unhooked my front abs an it still does it. any suggestions? And also I just put a big KY single disk clutch in me truck and sometimes it'll garb an shift like it should and sometimes it wont. Could it be the slave cylinder?
Old Mar 19, 2012 | 07:10 PM
rickf's Avatar
Check your motor mounts and transmission mounts.
Rick
Old Apr 2, 2012 | 08:08 PM
dozer12216's Avatar
for the brake vib. What condition of rotors or rear drums??
explain clutch issue better.
Old Apr 3, 2012 | 01:08 PM
SIXSLUG's Avatar
Sounds like an abs/speed sensor issue. Does your truck have the hydroboost?
Any codes?
The clutch issue could be related to your slave cylinder, they do only go about 100K miles.
Old Apr 8, 2012 | 05:09 PM
Jim n Sue's Avatar
Does the slave cylinder have a bleeder on it ? If not you need to replace with a prebled system Master & slave hooked together and do not separate them when installing
Old Apr 8, 2012 | 08:00 PM
afterburn 549's Avatar
Wow guys
1st Adjust up the rears (make sure you have shoes left too)
Next top off resivore .
Bleed brakes from rear to front
Now what do you have?
Old Apr 9, 2012 | 03:45 AM
Jim n Sue's Avatar
Did you retighten brake calipers after installing new pads ?
wildcargo
Nov 29, 2005 04:20 AM
95black2615
Aug 22, 2005 09:21 AM
JImbo1
13
Apr 18, 2003 06:44 AM
