No Brakes
No Brakes
I Have No Pedal At All Goes Rite To The Floor, Master Is Full With Fluid I Was Told The Master Needs To Be Replaced But What I Dont Get Is There Is A Brake Balancer Back By The Rearend That Is Missing Some Pieces Its Just Hanging There. Anyone Know About This??
Shouldn't cause you that problem, it just meters the proportioning front to rear based upon the load.
Master is where I would start, is your ABS light on? Do you have any resistance to the pedal going to the floor? Also, what does it do if you rapidly pump the pedal?
The abs and the brake light are both on. There is hardly any resistance at all, and when i pump them there is no difference, wont build up any pressure.
Fix the valve on the rear end (replace perhaps), then attempt a fluid flush on it, doing it in this order: RR, LR, RF, LF. If the pedal gets firm, all you had was air in the lines. If a no go, then replace the master cylinder.
95black2615
Aug 22, 2005 09:21 AM
JImbo1
13
Apr 18, 2003 06:44 AM
