New Turbo????
Old May 5, 2008 | 07:11 PM
Silver 002's Avatar
New Turbo????
So i got a new turbo silver 62 and it only came with two gaskets and two studs and nuts. Dont i need a electrical connector also for the electronic wastegate? I want to install tonight but it needs to run in the morning so... any thoughts?
Old May 5, 2008 | 07:22 PM
erf2006's Avatar
you will only need a dummy plug to cap the original harness. if the silver is like my htt 62 you can manually adust the waistgate so you need a boost fooler. i belive the smarty does this for you up to 40 or so psi.
Old May 5, 2008 | 07:30 PM
homewrecker's Avatar
You need the plug.It has a resistor so the ecm doesn't throw any codes.You can do a search on a DIY one.I don't recall the resistance off hand.
Silver 002's Avatar
k i heard of a bag trick around the stock sensor... will this work for a while?
Old May 5, 2008 | 07:37 PM
This might be what your talking about .
https://www.dieseltruckresource.com/...resistor+turbo
CumminsRedneck
Feb 18, 2013 07:51 PM
hoot
Apr 16, 2008 10:08 PM
Ada381
Feb 10, 2008 07:58 AM
kawi600
Jun 21, 2006 06:48 AM
HOHN
28
Jul 6, 2004 04:38 PM
