New Mods installed and impressions
Old Oct 3, 2005 | 03:32 PM
RAM2940's Avatar
Thought i would report my inpressions on new mods done to a 100 percent stock truck with 40000 miles. I make the same 350 mile trip once or twice a month so fuel mileage is accurate. Went over to Timinva's shop and had RV275's and a Vulcan pusher big line kit installed with new lift pump.
1. Stock truck:
A. Fuel Pressure, 10 idle, 7-8 Cruise, 5 WOT
B. Fuel mileage: City 17, Highway 55-63mph, 20-21
2. After installing RV275's and Vulcan big line pusher kit with new lift pump.
A. Fuel Pressure, 15-16 idle, 14-15 Cruise, 13-14 WOT
b. Fuel mileage: City 17, Highway 55-63mph, 22.5
After installing the 275s normal exceleration(about 6-7lbs boost) from stop, maybe a very minimal gain(almost no improvement).
Excellerating from about 55mph. Have a good gain. Seems to climb rolling hills alot better. Boost also comes up quicker. Seems to use less pedal to maintain speed. I am very easy on the go pedal and at highway speed i try to stay below 5lbs boost. Engine is alot smoother sounding at idle, does not hammer as loud, if i had to guess it sounds more like a 12valve.
On fuel mileage the old stock injectors did have some carbon build-up, so i think the spray pattern was not as a new injector. When truck was new i was able to get 21-22 on the highway, over time it did drop a little. Also use power service at every fillup.
All in all i am very pleased with the result, exspecially with the fuel pressure numbers. I think the RV275's is a very good install, it took a couple days to get a good feel for the results, but i do like them for the highway performance.
Thanks Tim for all the help you have given.
Old Oct 8, 2005 | 02:10 PM
Red3quarter's Avatar
RAM2940,
I'm going to be putting on the RV275 in athe near future in my 02. I was wondering if you are running a box of some type or a boost fooler? and if you are what is it?
thanks,
matt
Old Oct 8, 2005 | 03:50 PM
RAM2940's Avatar
No boostfooler or power box, i'm just running the 275s by themselves. I just keep a eye on the boost gage if i have to get on it, But i usally drive real easy. Still have a stock tranny.
Old Oct 8, 2005 | 03:58 PM
BigBlue's Avatar
Now throw an EZ on there and you'll really enjoy it. My trans held up fine to the abuse of an EZ/275 and I tried on several occasions to destroy it. The power was unbelievable and I still got 20mpg with the combo.
Old Oct 9, 2005 | 07:09 AM
Pike's Avatar
I also just put in 275 injectors. I have a Van aaken that I put an on/off toggle switch on. I never could get above 14.5 mpg with my old injectors no matter how easy I drove it, but on my first tank with the box on, no towing, and a fairly light foot, my mileage jumped to 17.9. I am very pleased with idle quality and quietness, mpg increase, responsiveness, and power. My boost went from 26 to 30+. I would definitely recommend these injectors for towing. The only thing I noticed is a little more shudder at low rpm like a HO with too much timing, but if I turn the box off that fixes that problem. I don't think there is much more smoke either.
GB 81
Dec 27, 2009 10:02 PM
Tree DR
Dec 9, 2009 11:03 AM
caffecapri
16
May 5, 2006 07:04 PM
WACTD
16
Mar 7, 2006 03:12 PM
1320
Oct 1, 2003 12:19 PM
