View Poll Results: Has your VP44 failed? If so there are 4 criteria:
Did you have bigger than stock injectors?
10.58%
Did you have banjo fittings?
1.92%
Did you have a fuel box?
26
25.00%
Or were you stock as a rock?
65
62.50%
Voters: 104. You may not vote on this poll
NEED YOUR HELP **statistics on VP44 failure**
Hey guys I'm doing a real statistical analysis on VP 44 failure, so the more responses I get the better. Has your VP44 failed? If so there are 4 criteria:
On this one I need all the help I can get. My hypothesis is that when using parts (e.g. banjo fittings and bigger injectors) with no subsequent pressure increase between the VP44 and the injector; the pump is subject to destroying itself due to a lack of fuel pressure between those two points. Thanks again for all the help.
Stock as a Rock.
VP died 3 months and 4,000 miles after I bought it brand spankin new, never even test driven before me, off the lot.
Still have the same lift pump putting out 15 idle, 10 at wot.
No codes ever thrown.
phox
phox
Originally posted by Homestead
Are you counting Max Flow Systems as "banjo's"?
Basicly I'm looking at anything between the pump and injectors that would increase the flow of fuel. But for the study I have to, for practical reasons, trim the choices down to 4. I chose the 4 I did because those seem, at least from my vantage point, to be the modifications that pop up most often between the VP44 and the injectors. Scott
Don't think the poll will help you much anyway as most folks have a stock system and thus more occasions for failure.
there was a thread on here 6 mo ago?? he knew how to take these apart and back again..it is the electronic thingy rotator assy? that measures the fuel that fails.......nothing todo with the pump.........The newer the pump the less chance of a dump
For instance, my whole eng took a dump (but thats a an other story)- and I have the same pump with drilled out banjos and 275 inj........nothing wrong with pump so far....................
well..was about 6 mo ago....mabe don m - i know it was a trust worthy dude not just shootin bull he was talkin about a swash plate assy that reg the amount of fuel and of course operated viaa elec motor of sone sort and that is tha thiny that fails acord to him.
Mabe "halin in dixie" might remember as he was having all sorts of problems about the same time with his engs.
