Need vac switch for 2lo conv.
Old 02-27-2008, 05:08 PM
fade94's Avatar
Mine went out. I got it used from a board member and can't find any info online on where to get this thing new. Does ANYBODY have a part number for a switch that you put on your truck for the 2-lo conversion? It has been working great up until the switch vac solenoid took a dive.
Old 02-27-2008, 05:18 PM
J Lent's Avatar
I haven't hooked mine up yet, but I got my vacuum solenoid from a junk yard. Just about any vacuum solenoid will work, they are a dime a dozen on ebay. You could use a Pacbrake vacuum solenoid from a exhaust brake. Advanced Diesel Technology sells them. 304-864-3399.
Old 02-27-2008, 10:45 PM
TNutcher's Avatar
doesn't need to be vacuum. A truck parts place should have a more than adequate pneumatic solenoid that would work as well and might be cheaper. . . good luck - mine is just a ball valve
TNutcher
Old 02-27-2008, 11:45 PM
1stGen545's Avatar
If you go manual you wont have that prob
heres what I did.
https://www.dieseltruckresource.com/...d.php?t=183893
JAyers
09-02-2008 11:25 PM
tonitto
12-21-2007 06:35 PM
bigthumper
08-24-2005 12:36 AM
nevrenufhp
06-04-2003 09:20 PM
Quick Reply: Need vac switch for 2lo conv.
