need a new TURBO (HELP!!!!)
currently with what i have in my sig, my little ATS 2000 is pretty much WAY small for the amount of fuel that i am running. i am at 1000 to 1100 egt wise going 70 on the freeway with flat driving. with the boxes on, pegs my egt guage at 1600 FAST and i dont know how much over 1600 it goes
wanted some imput on which is the BEST SINGLE turbo to get. truck is a everyday driver but NEVER tow so any help would be appreciated. thanks
Id say a Bell USB (62mm). Very streetable. Search them and see what they can do (my buddy is putting down probably over 900hp with on and one is also on the TS truck). They are the cadillac of modded turbos.
I don't know much about the ATS 2000 turbo, and it looks like you're running lots of fuel. Generally speaking, if you're running that high of egts while cruising at 70 mph, the turbo is to LARGE. If you've got egt problems at full throttle, the turbo is too small. If you've got both problems with the same turbo, you've got a problem.
Think about going to a smaller turbo along with water injection as a solution. A HTB2-12 or PS62 work well in this situation.
Well from reading on ATS's page the aurora 2000 isn't wastegated and runs best at 32-38 psi. How much boost are you seeing? You should be able to upgrade your turbo through II or HTT for a lot less than buying a new turbo if ya can deal with some down time.
Originally Posted by red70ragtop
Will ATS upgrade yor 2000 to a 5000? Or could you use your 2000 as part of a twins setup sold by ATS?
Originally Posted by dzlfarmboy
A B-1 Steroid would be pretty nice set up with the fuel you have and they seem t spool decent for their size.
