My VP44 is a Reman From CZ
Old 04-12-2006, 04:44 PM
Charlie8301's Avatar
The dealer replaced the VP 44 about 8 months ago, and the thing seems to run fine, but I kept hearing about the black pump from CZ being junk, so I got under the hood and checked it tonight, sure enough, it's stamped right on it, "Reman in CZ'. I've got about 25000 miles on it with about 8-10000 with the wire taped. Does anyone really have any hard facts the the CZ pump is junk?
Randy
Old 04-12-2006, 05:00 PM
smokindog's Avatar
If they replaced it under warranty I wouldn't worry about it, but since you tapped the wire.... that's another story.
I too heard that the CZ pumps were not desireable, that they weren't built to the exacting tolerance that the German manufactured units were. I have no real experience with them though.
Old 04-12-2006, 05:29 PM
J BODY's Avatar
I've installed quite a few of them and had to replace at least five of them before a years time had passed. One only went 9 miles and seized up. Seems that all the VP's are a hit and miss deal......just the CZ ones lean a little more on the "miss" end of the scale from my point of view.
Old 04-12-2006, 06:59 PM
Mike D's Avatar
You might get a good one, you might get a bad one. It's a crap shoot. I ordered a new pump and was sent a CZ, no thanks. I sent it back and got one reman'd in the US. It could crap out tomorrow. I tapped the wire before I cranked it up for the first time. I would try not to worry about it. It's kinda of like the 53 block. If it does go hopefully your dealer will treat you right.
Old 04-12-2006, 07:06 PM
Bob Wagner's Avatar
when you guys tap the pump wire after replacing a injection pump its best to leave it untapped or box off to work the air out for quite a few miles
just a heads up
Old 04-12-2006, 07:36 PM
Well I called II tonight and talked to Clint, he said the the CZ pumps seemed to fail a little more then the others, but it might run for a long time, you just don't know. For that matter I have a neighbor with a '99 with almost 200k on it, on the orignal pump. Decides that he wants some extra power so he buys an edge comp and taps the wire, I didn't think he'd make it around the block, but it's still running strong.
Thanks Randy
jrv15
01-05-2010 12:19 PM
J BODY
07-30-2005 10:25 PM
HappyGA
01-26-2005 05:58 PM
dodgediesel98
05-26-2004 09:28 PM
Palmetto_kid
02-25-2004 02:59 AM
Quick Reply: My VP44 is a Reman From CZ
