my pending setup
Old 03-19-2009, 07:59 AM
mt72916's Avatar
Question my pending setup
I am getting a p7100 pump rebuilt by pensacola diesel and I am having 191 DVs installed, stock plate, 3gsk.
at the same time I am putting in pensacola diesel stage 1 injectors.
planning on 15.5 -16 degrees pump advance.
will I have any problems with this setup?
this truck will ocasionally be towing about 8000 pounds (5000 lb fifth wheel and an 17 bass boat) and is not my daily driver.
I am looking for more but not excessive power and higher defueling RPMs for towing in the hills around here without excessive EGTs.
thanks to all that respond
Old 03-19-2009, 09:32 AM
JohnX's Avatar
That sounds like a good starting point. I would probably get some gauges if you don't have any. That setup will also allow for easy addition of power with a fuel plate if you're ever disappointed.
At that point your trans will be the weak link.
Old 03-19-2009, 08:45 PM
Tate's Avatar
Is your pump bad, why the rebuild? Pensacola has had some mixed reviews, so I'd look everything over with a fine tooth comb when you get it. 191's, 3k GSK and a plate should only cost your around $400, so unless you pump needs a rebuild, I would hang on to what you got and do the rest yourself.
Old 03-20-2009, 01:45 PM
BigErksG2's Avatar
agreed, that work is easy to do yourself too. I would also go with the 4k gsk because if you dont now, you will down the road. i would also grind your stock plate to about a 100 profile which makes logical sense as a function of operation and you can slide the plate back or forward to increase or decrease fueling. i had a stock turbo and 100 plate all the way forward and couldnt get over 1200* pulling a trailer up a long mountain (16.5* timing) with stock injectors.
rolling18
07-12-2006 12:19 PM
crobtex
01-05-2006 07:08 PM
Buckshotmckee
12-17-2005 11:56 PM
Quick Reply: my pending setup
