My homemade Boost controller install...
Just got done putting it in and after a trip to Home Depot, a performance shop for high pressure hose, and $30, its working perfectly.. Heres some pics. If you have any questions feel free to ask! Its not the cleanest job i have done, but ill clean it up after i play with it a bit.
From: In Oroville, Ca., same house for past 46 yrs!
how does this fool anything? I must be missing something here.
Also, why would you need "high pressure hose" for this item, regular fuel hose takes the pressure easily doesn't it?
I built a pressure regulator with vent similiar to what you have which doesn't open until a preset pressure, like 35-or 40 psi is reached, then when the boost is gone, like lifting off the throttle, the regulator closes and the vent takes care of the wastegate pressure so it closes.
Less than $10.00 in parts and used fuel hose.
Its not really fooling anything. This is purely mechanical and restricts air flow to the wastegate so it doesnt open completely as quickly. I was at 38ish PSI before this mod and now im at 48ish almost 50 PSI
They have inline boost controllers at www.boostcontroller.com.
I took a brass elbow ( free from work ) and drilled it and tapped it. Installed an allen screw ( plenty laying around at work as well! ) in the newly tapped hole that will close off the passage variably, and there you have it! A FREE adjustable boost controller!
I did the same, just used the stock elbow though. I think my total cost was .05 for the set screw.
Unless your set screw is bleeding off boost (like a boost elbow creates a small boost leak), you won't change the pressure, just the rate.
You mod increases the opposition to FLOW-- not the opposition to PRESSURE, which is why it is ineffective as a boost controller.
JMO
Høhn
