Multiple Injector replacement more prone...
Old 02-25-2008, 06:27 PM
Dieselcamper's Avatar
Are you more likely to have problems with leaks the more times
you change injectors ? I changed my original injectors for
RV275 injectors 40,000 miles ago and never had a leak or
any other problems. Now I'm going to get some Mach 1.6 injectors
and want to know if anyone has had more leaks on the second
or third time they have replaced injectors.
Old 02-25-2008, 06:29 PM
busa's Avatar
I think you should be O.K. To give you a good piece of mind would be to replace the O-rings on the transfer tubes with new ones.
Old 02-25-2008, 09:01 PM
Big Blue24's Avatar
I've changed mine twice, stock, rv's, to Jammers. No leaks!
Old 02-25-2008, 10:33 PM
Bjans's Avatar
no i wouldnt worry about them leaking.
Old 02-25-2008, 10:50 PM
rebal's Avatar
dieselcamper, you shouldn't have any problem and you will really like the mach1.6s super power great MPGs
Old 02-25-2008, 11:15 PM
busa's Avatar
HAHA, just noticed tonight that #3 transfer tube is leaking, new I should have changed those o-rings
rip 112
19
06-17-2008 09:38 AM
J_T
02-14-2007 09:25 PM
J.DAVY
10-15-2005 04:57 PM
SSV1761982
13
04-14-2005 11:07 AM
Quick Reply: Multiple Injector replacement more prone...
