How much HP do you have??
Old 01-06-2010, 05:58 PM
1999blackcloud's Avatar
Ive herd that your hp can be pretty limited with the trucks that have the vp44. Im just wondering what some of you guys are getting with your stock or aftermarket vp44? Let me know if your running stock or aftermarket also plz thanks
Old 01-06-2010, 06:06 PM
John_P's Avatar
Well, I don't have my 2002 Dodge CTD 24 valve anymore, but I got 540 H.P.
with the following modifications when I had it:
1.) Stock VP-44
2.) Scheid Lightning Injectors
3.) HX-40/16 Holset Turbo
4.) Aftermarket Fuel Pump/System
5.) Stock Headbolts
6.) TST PM 3 (Competition) "Stacked" with Edge EZ
7.) Full Billet ATS Stage VI Transmission
John_P
Old 01-06-2010, 07:57 PM
HOHN's Avatar
I'm probably around 400ish for "dyno" power with a Smarty and M4s
Definitely not real world useable for sustained runs. This combo will push a stock charger well past 40psi.
JH
Old 01-06-2010, 11:13 PM
DodgenIt's Avatar
From what Ive read in the past. Alot of power can be made with a stock VP. ithe biggest thing with it is if its a HO or SO VP44.
The HO's can be very restrictive around 450 HP I think? but ive seen dyno results of 5-600 on the stock SO VP44. Im sure more will chime in.
I havent dyno'd my truck but based on friends with similar set ups as me, I think Im around 350 RWHP. Next will be injectors and Smarty followed by coumpound studs and o-rings here.
HTH
Old 01-06-2010, 11:45 PM
Crazydave's Avatar
Stock SO VP 139,800 miles wire tapped since about 82,000
Mach 4's
Htt 62/71/14cm2
Quad Adrenaline
Supporting mods (exhaust air box etc.)
Dynoed 550hp Oct 3rd 09 on a Dyno Jet
Old 01-07-2010, 09:01 AM
CapnRam's Avatar
Stock SO, 210k miles, wire tapped...see my sig... Dyno'd last June on a mustang, 576/1310... with 125hp injectors, have 175's in the garage ready to go in with my new Southbend 3600 DD!! They OFE cant stand the pwr shifting!! LOL
Old 01-07-2010, 03:44 PM
Thanks ya'll! Now i cant wait to get my truck up in those numbers. I do have one more question. Whats the ho and the so stand for and which one comes stock on the truck?
Old 01-07-2010, 03:48 PM
nkennedy's Avatar
HO = High Output, found behind 6 speeds on 01 & 02 trucks. SO = Standard Output, found on most other 98.5 to 02 trucks.
Old 01-07-2010, 11:37 PM
DTR's Toad Wrangler
Clayten's Avatar
Well I have a 12 valve and all I had to do is change the air cleaner. Now I have 4x times the hp you 24 guys have
Old 01-08-2010, 06:29 PM
stroker4501's Avatar
your soooo cool clayten
Old 01-09-2010, 07:41 PM
roadrage1's Avatar
ohhhhhhhh,that was a good one
Old 01-09-2010, 08:50 PM
Administrator/Jarhead
madhat's Avatar
We're trying to build black cloud's truck into a monster.
I made a custom fabricated Edge bracket for it today, gave it an extra 10 hp...
Old 01-09-2010, 09:06 PM
Copenhagenjunkie's Avatar
Not enough and I would need 3 ft jobs to get any more .
Have fun building that monster!
Old 01-12-2010, 06:45 AM
Redliner's Avatar
Stock vp with 195k, drag comp, lightning 4's 7 x .018, 64/71/14, 285/75r16 tires and Goerend trans got me to 549/1093. Changed to Mach 5's and put on a set of 325/65r18's and dropped 7 hp.
Old 01-12-2010, 01:35 PM
Mopar_Man's Avatar
On my old engine with a HO pump I made 430 RWHP & 960 RWTQ with 3.55 gears & 37" tires on a NON loaded dyno. I have not yet dynoed with the new engine.
Quick Reply: How much HP do you have??
