How Much Boost?
Old 05-19-2006, 10:08 PM
6 Shaker's Avatar
How Much Boost?
While towing my 5ver which weighs around 10,000 lbs I can only build around 15 pounds of boost around 2000 rpm in 6th gear. I can easily build ~21-23 psi in 3rd, 4th and 5th gears at the same rpm. This is causing my EGT's to easily surpass 1250 deg. Is this normal? or should I be having the wastegate/turbo looked at?
LooseBoltsRob
31
11-16-2007 02:19 PM
MDMIKE
01-18-2005 10:02 PM
NeedMoPower
07-12-2004 10:04 AM
Cumminsdieselboy
10-27-2003 07:36 AM
Wes C
12-24-2002 12:28 AM
Quick Reply: How Much Boost?
