Looking for Pics of TALL CB Antenna's
Old Jan 21, 2005 | 08:26 PM
faster_than_ford's Avatar
Need your help guys. I'm looking for pics of trucks with 4' and taller cb antenna's. Usually when you get a cb antenna you get them mounted directly to the bed, when I was in high school one guy had his mounted on some sort of spring mount. The spring was loose enough to let them flop around like a old school metal whip aerial. If anyone knows what i'm talking about could you please let me know where to buy the "spring" mounts.
Thanks For The Help!!!
Old Jan 21, 2005 | 09:43 PM
Buckshotmckee's Avatar
I'll load a picture of mine in the mornin when the sun comes up. Mines not the spring type, but I know what your talkin about. The last spring type I bought was from Radio Shack.
Old Jan 22, 2005 | 08:21 AM
surfram's Avatar
I have a 6' Wilson silverload on a firestick extended stake mount. No problems.
Old Jan 22, 2005 | 11:58 AM
phox_mulder's Avatar
Radio shack might still carry the springs.
You could also check www.firestik.com, that's where I got my skinny springs, not sure if they have the old school fat springs or not.
Check my album, I have a couple pics showing my antennas with springs.
phox
Old Jan 22, 2005 | 06:25 PM
firestorm's Avatar
I will get pictures of mine tommorow. I have a 4' firestick mounted in the fender ( using a custom modified OEM am/fm mount) on the drivers side. I then added a small fiberglass whip to the original AM/FM antenna. This gives me two 4' antennas in the fenders, looks sweet.
Old Jan 22, 2005 | 08:04 PM
Pics finally loaded into gallery.
Old Jan 23, 2005 | 06:40 AM
gsdog1's Avatar
Buckshot:
That looks like what I am going to try and do. How did you mount the antenna to the bed rail? I have found a couple of brackets that look like they may work, but nothing that is specfically for that location.
Thanks!
Matt
Old Jan 23, 2005 | 08:45 AM
My Wilson came with a 90 deg aluminum bracket and bolts (stainless). I just centered it, drilled the 4 mounting holes, and 1 hole on top for the cable. If your having trouble finding a bracket, try a truck stop. I bought my set-up, antenna and cb from a Peterbilt repair shop.
Old Jan 23, 2005 | 02:31 PM
hotdram's Avatar
I was at Radio Shack the other day, and noticed they still had the springs for antennas. Try a truck stop as well. A lot of them sell CB stuff (Love's, T/A, etc).
FWIW, I mounted my scanner and CB antennas on the sides of my cross over toolbox. Both are 4 foot. I used a Firestik bracket and my own backing plate.
~Rob
halfpint23
Aug 11, 2007 09:21 PM
I PASS GAS
Nov 7, 2006 10:30 PM
silverbullet02
Sep 21, 2005 03:33 PM
RCC_SaMiaM
May 28, 2004 01:49 AM
