lockup ???
Old Jul 10, 2006 | 12:00 AM
makya's Avatar
lockup ???
This is my first post, and my first Diesel, so I'm a little new here...
I followed the diagram to hook up a lockup switch on my '01, but it doesn't seem to do anything other than let me know when the TC is locked by the LED light on the switch turning off.
I hooked it up to B11 and ran it into the cab to a rocker switch, then grounded to the metal frame under the dash. (I also hooked up the jumper at the relay).
The light on the switch shows when it's on until the TC locks up like it normally would, then the light goes off and it doesn't stay locked when I let off the go pedal.
Thanks in advance for any help..
Old Jul 11, 2006 | 12:25 AM
makya's Avatar
anyone have any ideas?
Old Jul 11, 2006 | 08:25 AM
V Baker's Avatar
If you followed these instructions,http://www.tstproducts.com/Torque%20...p%20Switch.pdf it should work.All you need to do is ground the B11 wire with a simple switch.B11 sends 5 volts to ground.Sounds like you have added a 12 volt source.If so?Dont think it will work.
Old Jul 11, 2006 | 09:41 AM
Mcmopar's Avatar
look in my gallery, there are three ways to do this, one is the TST way.
Old Jul 12, 2006 | 12:31 AM
makya's Avatar
Thanks, it looks like I wired mine with a 3-wire switch and it is leaving an open circuit
Angry Johnny
Aug 23, 2016 05:01 PM
93dieselZak
Jun 16, 2011 06:10 PM
JQmile
Sep 15, 2010 10:43 PM
Cowboy_Customs
May 6, 2008 09:39 AM
bear
Oct 16, 2002 10:35 PM
