lockers help!
lockers help!
i dont know too much about lockers...
... whats good?, where to get them?, and how much?... ive got a 2000 1 ton dually and i need something to give me a posi burnout but not keep me going straight off the road around corners... this is a high hp twin turbo application.... any help is appreciated
thanks
Jess
... whats good?, where to get them?, and how much?... ive got a 2000 1 ton dually and i need something to give me a posi burnout but not keep me going straight off the road around corners... this is a high hp twin turbo application.... any help is appreciatedthanks
Jess
I just did a detroit in mine. Its a little vilent sometimes but i got used to it and dont really know its there any more. It will make your tires chirp and hop on slow corners but nice at higher speeds. Any posi will be nasty on ice or wet roads, but the detroit is manageable.
Forgot about where and price. www.drivetrainspecialist.com where i went about 5 bills.
if they make a detroit ture track for a d70 or bigger id go with that it isint a true locker but i have one in the front of my blazer in a dana 44 and hits hard. the true track is torque sensitive and is a worm gear type i have been happy with it basically a limmited slip with good solid lock up darn near a locker
If you want a true locker, then for your dually application I would absolutely recommend the Detroit. It is, by far (IMO), the strongest locker available. Unless you can find a spool for the D80, but that would probably get downright ugly, real fast! If you don't want a locker, due to the hard lock and unlock of the Detroit, then I would suggest the Power Lock limited slip which is manufactured by the Dana Spicer corp. It is a great limited slip, probably one of the best out there. The fact that you can stack the clutches to get the firmness is really nice. I have had them set up where they were just as tight as a locker. If you decide for the Power Lock, look for a unit designed for a D70 HD. Same ring gear diameter. Just take it to a compitent machine shop with experience in ring & pinions and they will machine out the bolt holes for the bigger bolts that are used in the D80.
If Ox still makes a locker for the D80 it would be my first choice. The Detroit is a great locker, but the Ox is nice because its lockable/unlockable with a cable. The ARB is nice for the same reason, but you don't have to worry about wiring for the compressor, or air lines running throughout the truck. Pull a cable and go...thats it.
did anyone try that link?... i didnt like it so much... anyway what about this cable pullin locker? that sounds perfect.... lock it for competition/everyday diesel and unlock it when it rains ... any RELIABLE source anyone knows of?
thanks
thanks
What year vehicle do you have??Rick
2000 1-ton dodge dually 3.55 or 3.45 rear... i honestly dont know what dodge offered... i bought the truck used but i know its one of the two........the more i think about it the more i want the cable
guzzirider
19
Jul 20, 2004 04:53 PM
CharterBusDriver
Oct 6, 2003 09:03 AM
fail you!! Truetrac front!!
