lift pump questions
lift pump questions
well im pretty sure mines shot. i replaced the fuel filter yesterday and after i put the new one in a tried to build some pressure to fire the truck up. well i could have pumped the lift pump primer all day. it just didnt ever seem to build pressure. so im guessing that is not working any more. now my quetion is how long can i still drive my truck with out running the ip hot. the reason i ask is cause im just a broke high school kid. i planed on gettin the low pressure piston lift pump soon but not this soon
. thanks
. thanks
Well if you can buy online you should be able to buy a low pressure piston pump for around $100 or less. Then buying all the other little bits and pieces it should all stay under $200.
Although I don't like credit cards, they do come in handy in a pinch...
PULLTILBROKE has one on his pullin truck ,he has not hooked with it yet but said he can hold 15psi of more ot idle and somthing like 10 or so at WOT, i think i'm gona try one there like $50.00 on ebay.
You were sure that the cam in the engine wasn't compressing the spring so the lever is loose? Sometimes you need to bump the starter so the cam isn't compressing the lift pump, cause it won't do anything if it is.... pump all you want, nothing's going to happen.
In regards to the low pressure pump, i have not pulled my low pressure pump down below 10psi with my set-up.
well i noticed the motor is a lot louder than it used to be. it start this after i installed the new turbo. so i was thinking with the larger turbo that it is really burning the fuel and killed the lift pump.
