lift kits for 05's
Old 01-19-2005, 11:05 PM
ryans05's Avatar
lift kits for 05's
i have a 2005 2500 i want to lift it like 4.5 and run like 36's what would be a good lift
to go with
Old 01-19-2005, 11:14 PM
Jeff K's Avatar
Skyjacker, ProComp, Fabtech, Superlift, Tuff Country all make them. Prices are from $700 - $1500, so it is your choice. They will all do the job, it just depends whether you want a spacer lift or all springs.
http://www.rockymountainsusp.com/dodge4_03diesel.htm
Old 01-19-2005, 11:56 PM
Razor67's Avatar
Most people I talk to are using the pro comp. Pro comp addressed some of the steering issues. I know a few guys who got the death wobble after hitting an off camber bump with other kits. They installed the steering componets from the pro comp system and have had no more problems.
Old 01-24-2005, 10:54 PM
Patriot_RAM's Avatar
I've heard the same about Superlift... But on the same token, I posted the same type of question on the TDR a half hour ago:
http://www.turbodieselregister.com/f...34#post1123634
Old 01-25-2005, 02:11 PM
bchesley's Avatar
I just installed the 4.5 inch tuffcountry lift this past weekend. I lot it. Still rides great and no steering issues. I am running BFG 35x12.50 mt's and they look small now. Not that I want to go any bigger but I bet you could easily do a 36.
Brad
Old 01-25-2005, 05:47 PM
BUZZB8Z's Avatar
I've got a 6 inch Superlift with 37 inch Toyo M/T's and have not had a single issue. No bump steer, aligns great, no vibrations.
I'd do it again in a second...
Chad
Old 01-25-2005, 08:32 PM
triplenickel's Avatar
Thumbs up
bchesley your truck looks great!
Old 01-25-2005, 09:01 PM
bchesley's Avatar
Thanks, I need to take some pictures with the new wheels too. I will take one tomorrow and post it.
Brad
Old 01-26-2005, 04:25 PM
Kyle Graham's Avatar
Check out Whiplash they are complete coil lift in front no spacer. Rear leaf is all leaf no block, what I mean by that is you even scrap factory block. New leaf bolts right to axle the way lifts should be. Blocks just add leverage for axle wrap, kits also come with adjustable track bar. These kits come with lifetime guarantee
TheNeckasaurus
10-13-2010 08:16 PM
customizedcreat
05-19-2010 01:44 PM
LLoTuner
04-09-2008 11:28 PM
Igor
08-06-2007 09:39 AM
deputyski
04-03-2005 09:01 PM
Quick Reply: lift kits for 05's
