LED Clearance Lights
Old 05-31-2009, 02:10 AM
Dodgefan01's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Anybody run these? I've been wanting CAB lights for quite a while and ran across these recently. Downside is, you have to have wiring. I'm starting from scratch so i found a wiring harness for another 25.00. Just wandering if it's worth it for LED's.
Can't you change out the bulbs in the RECON kits for LED's??
Thank in advance for any information!
Johnny
Old 05-31-2009, 03:44 AM
LFD2037's Avatar
The recons are LED's.
Old 05-31-2009, 04:49 AM
Dodgefan01's Avatar
Directly from recon's site:
"Every kit is supplied with five Xenon gas filled 194 style bulbs"
That's why i was wanting to know thoughts on the LED set listed above on EBAY. They have 4leds to each light.
Old 05-31-2009, 06:42 AM
98whitelightnin's Avatar
All you need is 2 wires long enough to go from the driver side cab light to the dash on the passenger side. There is a harness that you tie into on the passenger side a-pillar for power.
Old 05-31-2009, 08:24 AM
aborgardt's Avatar
Look like the ones i had on my old 06. I had no problems with them.
Old 05-31-2009, 09:25 AM
ratsun's Avatar
I have the recons and really like them, however I believe they are sealed and the bulbs are not replaceable?
Old 05-31-2009, 09:31 AM
WhozNxtLS1's Avatar
I would like to see some pictures of what they look like installed.
Old 05-31-2009, 12:38 PM
LFD2037's Avatar
I don't know where you are reading that but follow this link & it will take you to the exact lights for your truck & they are LED's. BTW, you owe me a cold adult beverage!!!
http://www.gorecon.com/products.php?p_cat=29
Old 05-31-2009, 05:01 PM
Evil Genius's Avatar
My Recon's are LED...clear lenses with amber LEDs. They look white(clear) during the day and yellow at night.
Old 05-31-2009, 07:25 PM
Berak's Avatar
I had the first series of Recons and the lenses were crappy. Maybe they are better now but I doubt it. The chrome paint on the base fell off after a few years and they had to be siliconed down to seal well.
For the same price, I recommend getting a real set of LED, fully potted lights that are better designed and better quality. I put these on from Grote and really like them:
https://www.dieseltruckresource.com/...ferrerid=21038
They are not a direct fit, but it's just a matter of melting two holes through the base piece for a direct fit.
Old 05-31-2009, 11:26 PM
cbrahs's Avatar
Installed my RECONS over 2 years ago. ZERO problems and mine did not have lights from the factory. Like said above, make your own harness. remove the passenger side A pillar and there is a plug at the bottom of the pillar. take a meter and find the power when lights are turned on. this is the same harness used for the factory lights. Make your own harness for about $6-$10. I also did not use the RECON plugs and hard wired each light when we installed them.
installed
my buddy helping me install them
headliner removed
lights on
Old 06-01-2009, 12:46 AM
Dodgefan01's Avatar
Thanks for all the GREAT info!
Unfort. i can't see pics as this gov 'puter's firewall i assume is blocking them
Old 06-01-2009, 12:52 AM
Dodgefan01's Avatar
It deff. was NOT from this site. thanks man!
BTW, cold one on me! just find a way up here or i guess i should say up there (i'm not there right now)
Patriot2500
06-25-2008 08:47 PM
Ramcam
04-07-2007 03:43 PM
Mcmopar
71
02-27-2007 01:58 PM
cummins dsl
22
06-27-2005 11:53 AM
CHarlan
08-06-2003 08:40 PM
Quick Reply: LED Clearance Lights
