where this leak from?
I took my truck to the dealer a week ago for a little wet spot on the right front axle tube. and he said there was mud there and that it just was holding moisture and its ok. well i got under there today and noticed a huge we spot. can anyone tell me what this may be and where exactly its coming from? thanks
ill try to post a pic...
Hard to tell just from the photo but check the level in the front dif. If the shaft seal goes, fluid can/will flow down the tube and look sort of like your picture. See if you can get a mirror in to see if it's comming from the inside of the tube. If not look close and I am sure you will find the source
Good Luck
Good Luck
If they won't cover it, it's not hard just some time, a mess, and a bit of a pain in the but. Get a good shop manual I am sure you can do it. But leave it to them if they will cover it
