Last LP question
Old Aug 21, 2005 | 07:40 PM
2500Ram's Avatar
Last LP question
Should I hear the pump prime when I turn on the key while waiting for the wait to start light is on, not bump the starter.
Bill.
Old Aug 21, 2005 | 07:43 PM
99 cummins's Avatar
As soon as I say this someone will correct me, been a long time since I was stock. But no the pump should only run after you have bumped the starter.If I remember right I think I did used to get a quick spike of fuel pressure with the wait light though.
Old Aug 21, 2005 | 07:56 PM
2500Ram's Avatar
All right, I went out and got a quick surge no longer than it takes you to say this "PSSST" and a quick reading on the gauge to 3psi. Next time up to 6 psi, wait 5 seconds or so and 3 psi again.
I'M GOING NUTS AND SHOULD JUST REPLACE THIS STUPID PUMP
Old Aug 21, 2005 | 08:37 PM
99 cummins's Avatar
Anything below 5psi even dodge says is bad.
Old Aug 21, 2005 | 08:48 PM
2500Ram's Avatar
All things being equal, I do have a very small leak on a NPT fitting to the fuel gauge isolator, never a drop from the fitting but can get some fuel when I touch the bottom side of the fitting. I was told none of the fittings AN/JIT fittings didn't need anything but I forgot about the 1 NPT fitting. What should I use on that fitting to stop the leak. I would imagine teflon tape would be eaten up pretty quickly by diesel fuel.
Old Aug 21, 2005 | 10:38 PM
piperca's Avatar
Use liquid sealant. Keep it back off the first few threads.
You should only hear a quick buzz noise when the key is turned and the pump first cycles. This produces a reading of 5 psi for less than a second then drops to zero. When I bump the starter, I get 14 psi. I'm getting 14 @ idle, 12 @ cruise and can't get it below 10 1/2+ @ WOT. I wouldn't be concerned about the fuel pressure when the truck's not running. What readings are you getting while driving?
Old Aug 21, 2005 | 10:45 PM
Vulcan's Avatar
Yeah, what he said.
Hey Piper, whats up?
HawaiiCTD
Aug 27, 2007 08:51 PM
HOOKED
33
Feb 1, 2007 07:44 PM
howe719
May 27, 2006 09:05 AM
Tengu
Nov 7, 2005 01:57 PM
