Installed GFS 392 This Weekend
Old 03-26-2007, 01:53 PM
bhuffstutter's Avatar
I just installed the GFS 392 Performance Fuel System this weekend from GDP. I have to say that this is a quality kit. Everything you need along with good instructions. I was trying to decide what fuel/lift pump system to go with and I'm glad I went with the GDP system. My FP went from 5 psi stock to a steady 18 psi at the CP3 and when I tried to suck it down it wouldn't go lower than 13-15 psi. Install was pretty easy and I had no leaks on the first try. I would recommend this system to anyone looking to upgrade their fuel system. As a side note, I even think it made my truck run better, I don't know, maybe its my imagenation????
Old 03-26-2007, 02:06 PM
05CTDN8's Avatar
I have been told that the fuel systems feed the CP3 what it should be getting stock. I hate hearing that the stealerships are under feeding these systems causing premature failure. Not to mention adding substandard parts I.E. Lift pumps!!!!!! My GDP will be coming soon!
Old 03-27-2007, 12:24 AM
Shakin,
I would definately consider getting it soon, if anything it will give you piece of mind knowing that the cp3 is getting what it needs to do the job when the smarty is turned up and you have your foot in it....
Old 03-27-2007, 07:11 AM
MikeyB's Avatar
Planning to get the 392 in two months.
BTW, did you also install the 2 micron filtration kit? And the strainer?
MikeyB
Old 03-27-2007, 07:44 AM
BossHogg's Avatar
So if you can do regular car maintainence and repair a two stroke motorcycles top end, should you be able to install the GDP 392 in an 04?
Im just trying to see how easy it was to install? If I followed the instructions should it be pretty easy? And what tools are needed? Any irregular ones?
Old 03-27-2007, 07:48 AM
MikeyB's Avatar
Boss,
You can download the instructions from here. Seems pretty straight forward.
http://www.glacierdieselpower.com/sh...s.asp?pid=1008
MikeyB
Old 03-27-2007, 08:06 AM
BossHogg's Avatar
Dang, it looks real easy! Im gonna order it today!
Old 03-27-2007, 08:20 AM
Lost Lake's Avatar
Wow, $500 for a fuel pump?
Old 03-27-2007, 03:51 PM
MB,
I just used the strainer that GDP recommended with the kit. The price is on their website...
Boss,
Its a pretty easy install, the only thing I had to buy to put it in was a small tube cutter for the fuel line. I know you can do it.....
Old 03-27-2007, 04:25 PM
BossHogg's Avatar
Well thanks for the tip~
I ordered mine today, should be here in a few days!! THANKS LARRY!!
Old 03-27-2007, 04:33 PM
35" 05''s Avatar
wide open diesel.....300$ not those instructions are better but u can mailnly use those.
Old 03-27-2007, 05:00 PM
rustyshakelford's Avatar
how does it compare to the comp kit from glacier? i like the price better but whats the difference? and what would the out the door price be on something like that for an 06. i think i would need the draw straw?
brett
Old 03-27-2007, 05:09 PM
Sapps's Avatar
Pulling my big horse trailer I can pull it down to 3psi when I go to pass. Thats only Smarty level 1! Thanks Dodge
Ordered my 392 kit this morning, Went with the fuel filter/water seperator combo and going straight to the cp3 no more stock filter housing. Ill report back when I get it.
Old 03-27-2007, 05:42 PM
35" 05''s Avatar
brett
It is the walbro 392. I got the draw straw and the 35 micron filter for 350$
Old 03-27-2007, 05:57 PM
BossHogg's Avatar
well, even though that is cheaper, I wouldnt know if all the parts are the same quality as the GDP. Plus I am glad to help out the DTR store, as I had never talked to Larry, nice guy. He only sells parts on here to help keep the site running, and Im all for that!
Quick Reply: Installed GFS 392 This Weekend
