injectors
injectors
92 3/4 ton auto. 4 inch exhaust, big intake denny t fuel pin, and pump worked on,smaller turbo housing.next is injectors and maybe different turbo. what injectors should i use? want to have more pull power in the hills with big loads and still maintain my egts. would the bosch 190s be a good way to go? thanks for any info.
They are a good injector for mild good fuel milage, and they run cool. I have a set in my wifes truck and couldn't be happier with the results. Now if you are looking for a smoke billowing, tire burning, clutch slipping truck then they would be a little small. Hope that helps, and good luck with the new injectors.
darrenG
Jun 21, 2005 10:24 PM
