Hx35G
Old Dec 18, 2011 | 05:07 PM
Moparbubba's Avatar
Hx35G
Has neon tried to use a watercooled hx35g on a 1st gen? I figure fabing up coolant lines by teeing into the heater hoses. Its got a 14cm exhaust housing to.
Sent from my DROIDX
Old Dec 18, 2011 | 06:31 PM
Moparbubba's Avatar
Looks like its in good shape ne one know what size compressor housing its got?
Sent from my DROIDX
Attached Thumbnails Hx35G-uploadfromtaptalk1324254600497.jpg   Hx35G-uploadfromtaptalk1324254612496.jpg   Hx35G-uploadfromtaptalk1324254624004.jpg
Old Dec 20, 2011 | 12:50 PM
hounddogks76's Avatar
Do you know what it came off of?
Old Dec 20, 2011 | 01:07 PM
Moparbubba's Avatar
Yep a cummins cng powered bus
Sent from my DROIDX
Old Dec 20, 2011 | 06:08 PM
Theres an hx35g on ebay and it says in the description 60mm wheel
Old Dec 20, 2011 | 06:37 PM
Boatnik's Avatar
You got me wondering. What if you mounted a heavy duty trans cooler/fan combo and an electric pump. Or maybe a heater core/fan and a pump. With the fan you could mount the cooler under the truck and not use the valuble real estate behind the grill.
Old Dec 20, 2011 | 07:10 PM
Moparbubba's Avatar
The ones in Fleabay are 50mm compressor and 60mm exhaust. And a different part# but I guess if its a 50mm ill hybrid it.
Sent from my DROIDX
Old Dec 22, 2011 | 02:58 PM
Moparbubba's Avatar
Well found out its a 50/60/14 if I get it id have to hybrid it. How hard is it? And can the 35/40 back plate be swaped out like the h1e h1c hybrids? So far Im getting it pretty cheap.
Sent from my DROIDX
