Hummer 2 rims
Old Dec 17, 2003 | 09:12 PM
dra7's Avatar
Hummer 2 rims
Has anyone mounted a set of Hummer 2 rims with 315/70s on the SRW 2500/3500. I bought a set of 4 rims on ebay for $150.00, a lot of rich folks trading them in for 20 inchers and the market is flooded with them. The bolt pattern is the same, but I had to machine the center bore to fit my truck and I also opened the center cap bore to use my stock Ram caps. The problem is the offset is out a 1/2" greater, it helps clear the inside, but I don't know if I will clear the outer body. I will add a 2" level kit if I have to but would prefer not to. By the way I mounted 1 of them without a tire and it looked great with the ram center cap. Spent to much on my beast and have to save up for the tires.
Old Dec 18, 2003 | 07:08 AM
MikeyB's Avatar
Re:Hummer 2 rims
Sweet!
MikeyB
Old Dec 18, 2003 | 12:56 PM
Bertram65's Avatar
Re:Hummer 2 rims
How much did you have to machine the centers? Can yo use the stock lug nuts that came on the truck or do you need other ones? The tires should fit without a problem.
Old Dec 18, 2003 | 01:13 PM
DF5152's Avatar
Re:Hummer 2 rims
what size are the H2 wheels. Backspace and diameter?
Old Dec 18, 2003 | 01:46 PM
RamDan03's Avatar
Re:Hummer 2 rims
I believe they are 17" 8-lug 6.5” bolt pattern and 5.5” backspacing.
The look like they would be an excellent fit for us. I just found a set going for $180 on Ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2448875952
Old Dec 18, 2003 | 07:01 PM
dra7's Avatar
Re:Hummer 2 rims
The hummer wheels are 17", but they are 8.50" rims verses our 8.0" which is what the tire manufacturer recomends for the 315/70's. They have the same bolt pattern and stud diameter as our trucks. They also can use our stock lug nuts and our center caps secure to the lug nuts so you just have to machine clearance in the wheel for our center caps. I opened the center bore about .050" to 4.774 and the clearance opening to 8.50 inches for the center cap. The removal notch in the side of the center caps must be cut deeper or you will not get them off. A tire dealer freind says he just takes a hand grinder to do this to other wheels but I would machine them.
Old Dec 19, 2003 | 06:35 AM
Bertram65's Avatar
Re:Hummer 2 rims
Thanks for the info, I might try to find a set local, the shipping on a set of those with tires would be very high.
Old Dec 22, 2003 | 01:12 AM
Raspy's Avatar
From: Smith Valley, NV (sometimes Redwood City, CA)
Re:Hummer 2 rims
dra7,
I love the idea of the Hummer wheels! I called a local wheel dealer and he said they do get Hummer takeoffs sometimes and they sell them for $400. a set with tires. What a deal. The machining is the only glitch.
I think the stock Hummer tire is a 285 70 but I don't know the load range. Let us know what tire you decide on and how they fit, can't wait to hear.
Whatever I get, I want five, so I can run them on any position on the truck and rotate them all (can't run an odd size on one side of the rear with locking diff).
Thanks, Wetspirit
Old Dec 22, 2003 | 01:49 AM
LRAmberson's Avatar
Re:Hummer 2 rims
I looked at the rims to fit my truck but was to chicken to try them. . Now that you have ventured to the head of the pack I am sure alot will follow, myself included. Will be interested in your progress...
Old Dec 22, 2003 | 05:35 AM
RamDan03's Avatar
Re:Hummer 2 rims
[quote author=Wetspirit link=board=17;threadid=23914;start=0#msg227595 date=1072077145]
dra7,
Thanks, Wetspirit
[/quote]
Stock tires on the H2 are BFG All Terrain 315/70/17s (Load Range D) just like everyone is putting on their rigs already! It should be easy to pick up a set of 5. I see them all over ebay.
Old Dec 22, 2003 | 06:37 AM
Dodgezilla's Avatar
Re:Hummer 2 rims
I just ordered 5 BFG 315s from tire rack for $117.00 each plus $65.00 shipping!! I was planning on 285s but they cost $182.00 each!!! I'm using my stock rims as they have a little more backspacing then the Hummer wheels. There are lots of them on e-bay but most are too much $$$...
Old Dec 22, 2003 | 11:02 AM
RamDan03's Avatar
Re:Hummer 2 rims
[quote author=commando link=board=17;threadid=23914;start=0#msg227717 date=1072110480]
Are these different than the H1 rims? There is a new one parked outside and it has factory 37" goodyear Mud Terrains.....
[/quote]
Yeah, the H2 rims are a little different. The H1 sports 37x12.5x17" rubber.
Old Dec 22, 2003 | 11:17 AM
Deuce's Avatar
Re:Hummer 2 rims
For those that are interested I went the local Sams Club and bought a set of 315's for $542......$115.60 per tire........that included mounting balanced and lifetime rotation.
They had to order and will take 7 to 10 days
