how to hook this up
Old 03-25-2004, 03:29 PM
dodgeman01's Avatar
how to hook this up
I have two fueling boxed sitting at my house right now. the one is a bluechip and the other is a bullydog...the blue chip box has one fat red and black wire and one thin red wire and one thin green wire. where do these wires attach to?
2nd Box. bully dog
this box has the fat red and black wire and then the thin red wire but also has a fat green and black wire. how do you hook these up and whats the difference?
Thanks guys
DM01
Old 03-25-2004, 03:44 PM
BigBlue's Avatar
I'm guessing they didn't come with instructions? You could probably call up the respectable companies and have them email you a set of directions.
Old 03-25-2004, 03:50 PM
dodgeman01's Avatar
well I wish I could call but I just had my wisdom teeth cut out so I can't talk too well.
one other question. when you open the box up you see6 sets of jumpers one of the boxes has twoo of these jumped right in the middle and the other box has one jumped in the middle
DM01
Old 03-25-2004, 03:52 PM
Palmetto_kid's Avatar
sounds like someone cut the harnesses off. that sucks.
call the vendor.
Old 03-25-2004, 03:59 PM
dodgeman01's Avatar
the one has all the ends to it but the other don't. I don't know where they go
DM01
Old 03-25-2004, 04:07 PM
BigBlue's Avatar
Sucks about your wisdom teeth. I'm getting mine done beginning of june (right as summer begins) .
Old 03-25-2004, 05:29 PM
barracuda's Avatar
I got the Bluechip box, here are the instructions...
http://www.bluechipdiesel.com/BB%20INSTALLATION.txt
You should have a connector for the MAP sensor though, it sounded like u had no connector?!?
Old 03-25-2004, 07:45 PM
dodgeman01's Avatar
No I don't have the connector for the map sensor.
also I read the directions and it never said where to put the small red wire? it said where the big black and red wire but not the small red one.
Thanks guys for your help.
DM01
Old 03-25-2004, 08:27 PM
98 2500's Avatar
i bet the larger gauge red wire is for constant, and the smaller is for keyed 12v
Old 03-25-2004, 08:44 PM
dodgeman01's Avatar
Edited by Admin to remove ad.
Old 03-26-2004, 10:50 AM
dodgeman01's Avatar
Getting pretty upset now. I called both bully dog and they said that the box i have is a Edge product. I have seen many edg boxes and never one like this. I'm still trying to get a hold of Blus chip. Man this is turning out to be a pain in the butt.
DM01
Old 03-26-2004, 12:11 PM
psalm69's Avatar
Well you could e-bay them to offset the cost of a new edge comp. But I'm partial to the comp.
Old 03-26-2004, 02:17 PM
dodgeman01's Avatar
I got this box cheap and only plan of haveing the truck and the box until I get my 94 Dodge back from the tranny shop. then My dad is going to sell it and get a 04.5 dually.
DM01
Old 03-26-2004, 03:04 PM
barracuda's Avatar
The small red wire goes into the Fuse Box...# 9 , to use w/ the brass tap that should have been provided
Old 03-26-2004, 03:17 PM
dodgeman01's Avatar
What about the green wire? where does it hook to?
DM01
Quick Reply: how to hook this up
