homemade trac bars
Old 05-24-2010, 10:36 PM
coon-dog7070's Avatar
homemade trac bars
im thinking of making some traction bars for the old dodge (^^^). ahave good mechanic skills and im confident in my welding so i know that i can make them. does anybody have any specs on how the built theirs or how they would build theirs.
Matt
Old 05-29-2010, 12:20 PM
pgdsm's Avatar
Would be curious what others have done as well.
But i was thinking I might try it with some 1.75 Dom tubing about 60" long. To a shackle type joint ( don't know what it would be called but picture it in my mind) i would run two tubes obviously but bend one to save as much ground clearance as possible.
Old 05-29-2010, 12:36 PM
dodgetrucker75's Avatar
here is what i did, i jot some centerlinks for a tractor @ john deere, cut in half and extended them, then made a plate for the bottom of the u-bolt plate, ran the u-bolts through the plate, then made brackets front and rear, and welded up
Old 06-01-2010, 05:29 PM
im thinking of doing something similiar to this, being adjustable is always a plus. i think i need 1/4" wall tubing and then the adjustable end links
starflite3
10-29-2009 05:40 PM
dieselcarpenter
09-27-2007 01:49 AM
24valver
08-11-2005 09:24 AM
Toby
08-17-2004 01:35 PM
Quick Reply: homemade trac bars
