holly pump install
Old Oct 12, 2008 | 12:41 PM
bryanburns's Avatar
holly pump install
need detailed install directions step by step for holly blue stock pump has a crack in it. need to install holy and bypass old stock pump what to do need help
Old Oct 12, 2008 | 07:57 PM
rich's Avatar
i put mine as close as possible to the tank on the frame and hooked it up to a fuse that worked when the key is on. did not use the pressure regulator. its pretty simple if you have some mechanical ability. took me about an hour and half
Old Oct 12, 2008 | 08:34 PM
Night Rider's Avatar
That or you can use a wire run from them old pump to trigger a relay that way you still have the pump priming up your system. I'll look around and see if I still have the write up I did awhile ago and PM you with it.
Old Oct 12, 2008 | 08:40 PM
dropped2500's Avatar
where is your stock pump located? if its on the back of the filter housing you can go to vulcan performance and buy a block off plate and run the line from there to the pump.
griffy
Feb 13, 2008 08:03 AM
PowrStorkthsRam
Aug 26, 2007 02:49 PM
BRD
Jul 15, 2005 06:31 PM
OldSmokey
Jan 28, 2005 07:16 PM
Tengu
33
Apr 27, 2004 09:03 AM
