Holley Blue Transfer Pumps
Old Oct 27, 2004 | 11:38 PM
TireHauler04's Avatar
Question Holley Blue Transfer Pumps
For those of you all running one of these pumps, how long have you gone before it "died".And what happened when it gave up, did it just die overnight or did it slowly loose pressure on you,or did the solenoid quit? Appreciate the info..thanks
Old Oct 28, 2004 | 07:20 AM
Ryan's Avatar
I've been running one for over 25K and it hasn't died yet. The pressure did begin to drop one time. I pulled the pump off and reomved the bottom cover to find some small pieces of debris. I cleaned everything and put it back together with a new gasket and haven't had a problem yet. The Holley Blues do seem to have their limitations as well. Based on experiments with my truck the seem to reach their limits at just over 500 Rwhp.
Old Oct 28, 2004 | 08:47 AM
J BODY's Avatar
For all the guys I see with failed Holley Blue pumps at the race track over the years I don't think I would rely on one for a daily driver.
Old Oct 28, 2004 | 05:13 PM
Scotty's Avatar
Top's Younger Twin
I had a Holley Blue on my 01 for over 50K miles...no problem.
I have one on my 04 Ram now with over 10K.
However, I know of folks that have defective ones from new and others that have had pumps fail in a few thousand miles.
On the 01 I had DD3's TST comp stacked with an EZ, B1 etc etc.
I have an old EZ stacked with a VA now.
Fuel pressures are great.
I also tried other pumps...Carters, Aeromotive, and a few others...all of which failed. One in particular failed with less then 300 miles and it was a PE. Replaced it and failed again.
Holley Blacks do not like me...EVERYONE of them failed.
I hate to say it but it can be a crap shoot.
Old Oct 28, 2004 | 06:34 PM
gamiller31's Avatar
What Scotty said. I had a stocker, Holley Black, and current Holley Blue. So far so good. Good thing is, every Oriely Auto Parts store I have called , has the Blue in stock.
Old Oct 28, 2004 | 08:07 PM
cumminsboy's Avatar
Ran one on my race truck for 3 years and never had a peep of trouble out of it. (Holley Blue).
Old Oct 28, 2004 | 09:14 PM
mooseman's Avatar
Fried a blue in 1000 mi. One day it worked great the next morning it did not work at all. Im on the second blue now for 5000 mi. and not a bit of trouble so far.
mooseman
Old Oct 28, 2004 | 09:54 PM
01redram's Avatar
is there any such thing as a good reliable lp? you guys are scarring me! i feel life i should carry a spare in my glove box
Old Oct 28, 2004 | 10:12 PM
Geico266's Avatar
Why do you think your Dodge has all that room under the back jump seat?
I just replaced the stock LP for the 2nd time in 155K miles. The first one went 130K miles, the second 20K miles. I'd say stick with the stock pump on an "01".
Old Oct 28, 2004 | 10:52 PM
01redram's Avatar
guess i better buck up for some gauges.could save the cost of a injector pump!
Old Oct 29, 2004 | 07:43 AM
gamiller31's Avatar
01redram - exactly..., and there is no electric FP that will last as long as you want it to. You can go mechanical(RASP) if you want.
Old Oct 29, 2004 | 09:54 AM
cmnspwr's Avatar
I don't know what sort of quality control Holley uses, but it must be slack. I know folks swear by the reds and blues and have had no trouble whatsoever with them (John_P and Banshee), but I had two red pumps let go in 6 weeks. Both times I was on the road, noticed fp drop to zero instantaneously. Getting towed twice is not fun. So, I traded for an 03.
Some are good, some are bad. Its a crap shoot.
Old Oct 29, 2004 | 09:57 PM
HOdiesel's Avatar
Crap shoot? I don't think so. How many people had a bad blue pump in the truck that used a fuel filter before the pump.
I guess if you not savvy about roaside repairs you stuck towing your truck. I think it is correct that some dirt gets into the pump and causes it to go to zero pressure.
I'm using a Holly Blue that replaced the lift pump. After 10K miles, no problems.
For me, if the pump's motor is spinning, i can fix it on the roadside.... Much better than the stock pump which can't be repaired.
My 2 cents
HoDiesel
Old Oct 30, 2004 | 07:32 AM
TXRAM2's Avatar
Can the Holley blue be used in the stock location? If so what does it take to install? Any different fittings etc.?
I have my second lp dieing now, and not sure whether to go blue or pick up another from Cummins.
tia
wayne
Old Oct 30, 2004 | 11:10 AM
HOdiesel's Avatar
I wouldn't worry about getting it into the stock location too much. I put mine on the frame rail near the fuel tank. The output of the Holley pump goes directly into the fuel filter.
So far I get 15PSI cruising, 15PSI idle, and 14PSI WOT. I do notice if i'm working my truck hard (pulling a horse trailer up hills) that after a while the fuel pressure rises to 17PSI. I never seen that performance on a stock lift pump.
HoDiesel
