hid problems help!!!
Old 12-26-2008, 05:01 PM
ryans05's Avatar
i got some hid's for my 05 for christmas from the gf went to put them in tiday an they dont work does any know the right way to wire them they are a plug an play type but nothin. when i check the volts at the light socket it gives a pulse reading. any help would be great thanks
Old 12-26-2008, 05:19 PM
04DEEZELRAM's Avatar
You will need to run resistors to the low beam wire to make them work, i used a 8 ohm 20 watt resistor from radio shack.....uses a t-tap and go from the low beam wire to a ground, that fools the ecm and they should work, i just installed some on a 05 last week.
Old 12-27-2008, 01:22 AM
cbrahs's Avatar
or you can contact www.hidspeed.com and tell them your issue. they made me a harness with capacitor/resistor already in place and the harness uses both factory headlight sockets to operate the HID kit.
Old 12-27-2008, 02:03 AM
CrashCade's Avatar
X2. I didn't get mine from this place, but this is your problem. Just need the capacitors and resistors!
Old 12-27-2008, 09:12 AM
jiggerman78's Avatar
Sorry for hi-jacking but I'm also having a problem my kit works great. The only problem im having is every once in a while i will go over a dip and my lights will flicker once. It happens every once in a while. Also the daylight running lights + HIDS seem to be a big problem and i have to drive around with my headlights on during the day to kill the buzzing sound if i dont turn the lights on. Any suggestions??
Old 12-27-2008, 04:35 PM
trik396's Avatar
I used the same 8ohm 20 watt resistor. It lasted a month maybe a bit longer then the resistors gave up the ghost. I am currently waiting on the hidspeed kit that will do away with the problem. For $45 it's probably cheaper than if I built it myself.
BoOsTcRaZy
31
02-16-2008 08:08 PM
Eric Logan
01-02-2007 08:09 PM
223 rules
11-01-2006 06:12 PM
04ctd
05-31-2006 05:54 AM
Quick Reply: hid problems help!!!
