HELP! throttle linkage washer size
So you know that little steel washer that sits IN the plastic washer under the throttle assembly? It's removed during the VE spring install...anyway...what size is it??? Is this something I can replace at a hardware store or is it a specific cummins part? I ask because I had to remove it tonight in the driveway as part of a fuel line install (don't ask) and it went falling to the fifth dimension. In the off chance (I hope) that I can't find it tomorrow I'd like to get another so my pump shaft won't leak. Anyone??? I'm not a happy camper at the moment. Hopefully a little coffee and sunlight will locate it tomorrow....
If you can't find it, I would think a washer of a close size would work fine. As long as it fits inside the plastic washer and is around the same thickness you should be fine. I think it is a split style lock washer IIRC.
