HElP need ideas on disabling van A.S.A.P
Old 10-06-2004, 10:44 PM
4doogie's Avatar
Hey guys, i need ideas on how to make a ford van not work. this is not my ride, but my family that owns it has been told not to drive anymore. The van still has to run, but only for the use for moving it around. i've tried a wheel lock and he got though that. thanks for any ideas.
chris
Old 10-06-2004, 10:47 PM
HorseHauler's Avatar
take out the negative terminal cable and hide it??? im confused about all this...
Old 10-06-2004, 10:51 PM
4doogie's Avatar
well heres the story, gramp just turned 80 and doc says he shouldnt drive anymore. and he's been in 2 acidents in the last 2 years. not that bad, but his fault. heres the thing hes smart enough to fix the terminal cable. so far i took the battery out but he will just buy a new one.
chris
Old 10-06-2004, 11:00 PM
dieselminded's Avatar
just sifion the gas out hes too old to walk to the station and when you want to move it put alittle gas in it
you can also cut the fuseable link that goes to the battery and tape it back up but dont let the wires touch when you want to move it just connect the wires he'll never notice that they wernt taped up before.
Old 10-06-2004, 11:01 PM
wgingg's Avatar
take the rotor off and put the cap back on. 5 mintues max
Old 10-06-2004, 11:05 PM
blown32's Avatar
I have used vacume hose to mess with friends, it might work. Replace the coil wire (if it's an old enough van to have a coil) with a short vacume hose of the same size. With the boots on it looks just like the original.
The rotor is the best way, but not as much fun to watch folks try to find.
Old 10-06-2004, 11:07 PM
4doogie's Avatar
see thats the thing hes smart he could figure that stuff out or call a truck repair place.
Old 10-06-2004, 11:08 PM
4doogie's Avatar
i cant get to the rotor without work it sits to far in
Old 10-06-2004, 11:09 PM
wgingg's Avatar
well if its like that drop the drive line and take the yoke home with you!
Old 10-06-2004, 11:10 PM
wgingg's Avatar
or a "club" for the steering wheel
Old 10-06-2004, 11:11 PM
4doogie's Avatar
but i still need to move it without too much work, see its parked at my house now.
Old 10-06-2004, 11:12 PM
4doogie's Avatar
i was thinking kill switch very well hidden
Old 10-06-2004, 11:14 PM
wgingg's Avatar
good idea, maybe also a start button tucked under the dash
4doogie's Avatar
tried that it didnt work
Old 10-06-2004, 11:17 PM
wgingg's Avatar
plug up an inline fuel filter with gas tank sealer. this is kinda fun
Quick Reply: HElP need ideas on disabling van A.S.A.P
