Help Me Choose A Turbo And Fuel System
Old 02-01-2008, 12:55 PM
Ghost Ram's Avatar
well im ready to decide on a single turbo and a fuel system to meet my needs and future plans which include 550 hp range, quick spool up, street/strip, and light towing (3k lbs.). i will be using everything in my sig including my smarty most likely on sw7or9 aftermarket turbo program. i will also most likely add a pressure box such as an ez or mp8.
So far for a turbo i have been planning on the htt 62/71ss or something similar, suggestions would be greatly appreciated. for the fuel supply i want to start off by keeping the stock cp3 and stix, and just adding something like the gdp walbro system, air dog100 or raptor100. again suggestions would be great. will any of those systems work w/o cutting my tank? then if necesary i will add a cp3 and stix afterwards.
thanks again for any help or suggestions, its always appreciated.
Old 02-01-2008, 01:37 PM
rip 112's Avatar
I like the Airdog, it s the most thorough kit for the money. the 62-71-13ss should suit you fine. I willl be going with the 64-71-13ss for my early 04. I have about the same goals as you, but I probably will do some sort of injectors..
Old 02-01-2008, 03:01 PM
Super Googan's Avatar
With your year truck you will have to drill the tank because you have the lift pump in the tank.
You should go with the 150 airdog or raptor. The only advantage to a airdog 100 is for the 2003-2004.5 trucks that don't have the in tank lift pump. You don't have to drill the tank on those year trucks with the 100 but you do with the 150 because the pickup is too small for a 150gph pump.
Old 02-01-2008, 04:13 PM
jerrywoodie's Avatar
glacier diesel fuel boss pump and a hytech 62/14/71 series turbo works great for me
Old 02-01-2008, 06:46 PM
Ghost Ram's Avatar
i like the airdog as well, i just dont look forwrd to cutting my tank. i guess i will have to do that w/ any aftermarket fuel system huh?
i was looking at the 64/17 but htt says some customers report surging during towing or daily driving and i figure if the 62 ends up being too small i can always send it back in for an upgrade. i didnt see the 62/71/13ss on htt's website. i only saw the 62/71/14ss. what is the difference between the 13 and 14?
jerrywoodie, how does your 62/71/14 spool compared to the stock turbo?
anyone else have any other options or suggestions for me?
Old 02-01-2008, 07:13 PM
Eddy Reyes's Avatar
Turbo
Get this one!!!(single, stage 3)
http://www.turbobygarrett.com/turbob...004.5-2006.htm
Old 02-01-2008, 07:20 PM
there is very little lag since i added the gdp intake horn and heater delete block, it pulls very well no surging problems
Old 02-01-2008, 08:01 PM
rip 112's Avatar
I think the 13cm housing has better control of egts over the 14cm
Old 02-01-2008, 08:16 PM
Ghost Ram's Avatar
Originally Posted by Eddy Reyes
how does the garrett gt37r compare to the htt 62/71? its a ball bearing turbo correct? are there alot of guys using this turbo now, and how are they holding up? if its close to the same size it should spool faster being ball bearing.
i would be able to get garrett turbo's at cost from a friend. maybee i should look into it some more.
i have decided on the air dog but not sure if i should get the 100 or 150?
Old 02-01-2008, 08:25 PM
rip 112's Avatar
The 100 is supposed to hold up to 550hp, maybe hold even more!
Old 02-01-2008, 08:36 PM
Ghost Ram's Avatar
well both are about the same price, what would be the down side to getting the 150 and not needing the extra flow. is the install different for both?
on htt's website i am seeing the stainless housing in the 14cm and the ductile iron housing in the 13cm. does this sound right? so i guess if i want the ss housing it would have to be 14cm??
Old 02-01-2008, 10:01 PM
Spooler's Avatar
SS housings are either 13 or 16. The 12 and 14 are the normal cast housings.
Old 02-01-2008, 11:27 PM
Sandaholic's Avatar
i like the airdog as well, i just dont look forwrd to cutting my tank. i guess i will have to do that w/ any aftermarket fuel system huh? Here is an alternative to cutting the tank
https://www.dieseltruckresource.com/...d.php?t=189220
But, I guess if you plan on the 550hp range then the AD100 will work fine. It looks to me like you are planning q decent list of mods over there though.......you sure you're gonna stick with 550 ???
Old 02-02-2008, 12:05 AM
Sinbadd's Avatar
I am interested in this turbo too but not too many folks on here are running this one. I made a post about this turbo not too long ago and there weren't many replies, although someone said that there was an artical in TDR magazine where they replaced one of the more popular turbos with the stage 3 and had quite an improvement in spool and power. There seems to be a bit more info on the 2nd gen forum. Check under the posts by hon. He is one of the more frequent posters on that forum who seems to know quite a bit about the Garrett turbos.
Old 02-02-2008, 07:55 AM
Dieselhed's Avatar
Ghost. If your aiming for 550, IMO you should build for 600-650. A truck capable of hitting 600+ will make a daily driving 550 much more efficient, with lower egt's. Few people can build a truck to thier preferences the right way, the first time. It's alot of trial and error. Most will buy expensive parts only to find they want more power, thus selling thier expensive parts at a loss only to buy that turbo that is a "little bigger". I did alot of reading and listening to others on this same turbo topic, and rode in several truck with different turbo set ups, and decided on the HTT 64/71/13 (which I will be picking up today). Take your time, and good luck with your decision.
Quick Reply: Help Me Choose A Turbo And Fuel System
