HELP, hub bearing assy removel
Old 05-23-2009, 03:16 PM
03CTDCO's Avatar
Having difficulty removing the hub bearing assy to replace
my ball joints. Seams to be froze in there. Any tips or tricks
to get these out without damage ?
Old 05-23-2009, 08:24 PM
benroberts3605's Avatar
this has worked for me everytime, i loosen all the bolts start them back in and then using an impact socket and short extension. place the socket assembly back on the bolt, i place a prybar against the extension, find a solid spot too wedge it against start the truck and use the power steering to push it out, ive done it several times on 2nd gen trucks
Old 05-23-2009, 08:39 PM
garr_trenching@'s Avatar
I had good luck with the way benrobert3605 described other than I used a buddy to turn the streering wheel while I carefully held extension, Little pressure on front then back then popped right off. Good luck.
bling
11-30-2009 12:06 PM
Rob_OBX
15
02-21-2007 06:36 AM
Rob_OBX
02-21-2007 06:32 AM
MasseyMan1089
05-30-2005 05:13 PM
Quick Reply: HELP, hub bearing assy removel
