Help with 03 needed.
Old 06-17-2010, 12:34 PM
Jboss's Avatar
Hello folks. I have been hangin around reading the boards for a long while now and now I have run into a problem with my 03 thats got me pullin my hair out by the roots.
Heres my Truck
2003 Dodge 3500 4x4. auto trans. EVERYTHING is stock save the aftermarket fuel/lift pump.
Heres some of the problems I'm having.
#1. NO CODES. Yes I said no codes. Not a one of them.
#2. NO POWER. This thing wont pull a sick wh*^e off a pee pot.
#3. Increased noise comming from motor.(fuel knock????)will go away if one of the lines is cracked open
#4. Black smoke/white smoke.....Raw fuel smell
What I have done so far.
#1. Checked for codes.
#2. Checked fuel supply
#3. Checked ALL lines
#4. Repalced APPS on the advice of dealer.
I've been working on this problem since sunday and I'm about at my wits end.
Can anyone help?
Old 06-17-2010, 12:58 PM
orangebronco68's Avatar
Check your grounds. Both at the batteries and the body grounds.
Old 06-17-2010, 06:50 PM
1985cucv's Avatar
yeah check grounds.
make sure you got fuel pressure
there is a wire on the newer trucks but yours might be affected to that is by the passenger side frame that rubs on the frame and motor i believe it is pink my 03 had wire loom on it but some do not just look for a pink bare wire towards the front a little infront of the turbo
Old 06-19-2010, 12:27 PM
cLAYH's Avatar
Sounds to me like a boost problem. Check your turbo, exhaust, intercooler and all of your piping.
If its an auto you can step on the brake and gas together in gear to try to make a bit of boost while someone sticks there head under the hood and looks/listens for a boost leak. Obviously some caution is required with this.
Old 06-19-2010, 12:36 PM
Tacomaman87's Avatar
injectors
Old 06-19-2010, 05:19 PM
RTillery's Avatar
Here's what mine did. Sounds kind of similar. Good luck!
https://www.dieseltruckresource.com/....html?t=269803
Old 06-21-2010, 09:36 AM
Jboss's Avatar
Thanks everyone! I'm back under the hood of this POS now. Thanks!
Old 06-21-2010, 11:13 AM
dieselfreak21's Avatar
If you don't find a ground issue sounds like an injector or pump. Cracking the lines on these truck with it running is not recommended and would have spewed a ton of fuel all over the place. What is the oil level? IF above full then likely injector has died. The deal should have done a shut down test to find which one. When mine when out power was down and engine was noisy(only noticed it with rebuilt injectors as truck was quiet again) Smoked at idle. White at cold idle brown haze at warm idle. Good luck.
Old 06-21-2010, 01:48 PM
michael/edge's Avatar
i have posted on a couple of other forums about my dads 03 acting up. first his cam sensor went out. and it threw no codes. and his truck would just die and go slow and blow smoke.
so he got the cam sensor fixed then the truck died again. and again no codes. they found wires rubbing on the frame.
so just maybe your cam sensor is bad to.
Old 06-24-2010, 11:10 AM
Jboss's Avatar
Thanks again for the input. I think I have 3 injectors going down in this POS. Had a mech do a cyl cut out test and he says injectors 1,3,4 are not working correctly. We will see shortly. Now I'm searching for threads on how to remove these injectors correctly.
Thanks thank for all the help and ideas. I will keep you posted.
Old 07-06-2010, 11:00 AM
FWIW, if 3 are bad, have them all rebuilt.
Old 07-06-2010, 11:21 AM
FMB
FMB's Avatar
Originally Posted by Jboss
.... Had a mech do a cyl cut out test and he says injectors 1,3,4 are not working correctly.
Someone on here has a great posting on removal of your sticks. F1 has a great reputation on re-tipping and rebuilding. Check them out and good luck.
Back to morning brew. . .
Old 07-07-2010, 02:44 PM
BLACKBEAR's Avatar
I would check for a BAD wire!! defore you do a lot of work that you might not need.
Old 07-07-2010, 02:47 PM
BLACKBEAR's Avatar
I would check for a Bad wire!! Before you do a lot of work that you might not need.
Old 07-07-2010, 02:54 PM
BLACKBEAR's Avatar
Hi I am back. You need to read the post on here that says Every one needs to read this Shorted WIRE this might help you. === good luck ===
Quick Reply: Help with 03 needed.
