Heating oil/diesel mix
Old 01-10-2007, 04:38 PM
sleepr tsi's Avatar
Is there any danger in heating my veggie oil cut with #2? It's about about 90% veggie oil and I'll be using a bucket heater like thishttp://www.mytscstore.com/detail.asp...roductID=15554
I'm thinking that with the block heater and the veggie already hot I should be able to use the eggie oil in the first few minutes.
Old 01-10-2007, 06:52 PM
Need95-00CTD's Avatar
As long as your veggie oil is about 160* your fine, make sure its filtered well though. Most guys running SVO/WVO use coolant lines run through the tranfer tank to heat the oil...I wouldn't want to have an open electrical connection in my fuel tank...even if the flashpoint is about 400*, just my opinion, good luck.
Old 01-10-2007, 08:33 PM
sleepr tsi's Avatar
There is a coolant line throught the tank, and through the feed line in two spots. Just trying to cut down on the wait time.
ramoszx12r
10-22-2011 04:33 PM
12valvin
03-02-2011 03:46 AM
simonswb6
08-27-2003 05:21 AM
fanofthewolf
08-25-2003 11:05 AM
Quick Reply: Heating oil/diesel mix
