Heat shield template
Old 11-13-2003, 07:34 AM
Palmetto_kid's Avatar
Im guessing you print this out on 8.5x11 to get the right scale?
Old 11-13-2003, 09:23 AM
berner's Avatar
Re:Heat shield template
Print each page out on 8.5 x 11 and tape them together. Vegasbound gave me a great tip. He told me to cut it out of a piece of cardboard and use that to position it. Once you got it where you want it, press down on the airbox mounting studs to punch holes in the cardboard. Then use the cardboard as a template to cut the final heatshield. Worked great.
Old 11-13-2003, 05:05 PM
phox_mulder's Avatar
On the same note, here's what I did.
I drilled 3/4 inch holes in the heatshield that lined up with the factory box studs.
Pulled the rubber grommets and torx nuts out of the factory box, and pushed them into the holes in the heatshield.
Holds the heatshield down nicely.
Here's a link to my install thread if it helps any.
https://www.dieseltruckresource.com/...7023#msg157023
Two part thread, bumper then BHAF.
phox
Old 09-06-2004, 10:03 AM
taken5875's Avatar
I could not print or down load the template could some one email me a copy taken5875@cs.com thanks
SSweeney
07-17-2006 10:28 AM
Mark65
04-10-2004 08:13 PM
psdctd
02-24-2004 12:58 PM
Cumminsdude
13
08-04-2003 05:56 PM
boehunter49
03-06-2003 05:27 PM
Quick Reply: Heat shield template
