headlight relay ?
Old Jun 11, 2011 | 10:09 AM
Lunds Ram's Avatar
Unhappy headlight relay ?
I just did the headlight relay mod and I have a small problem, the drivers side head light is on brights when the other one is on dim and it goes dim when I hit the brights, I've switched the wires around and nothing so far has fixed it, what did I do wrong?
Old Jun 11, 2011 | 10:31 AM
ppiggppenn's Avatar
My DRL does that, dvr side bright and pass side reduced intensity. I've improved the grounds to no avail. I just run brights now instead of DRL, and my low beams are OK. I have a sneaky feeling that the solution to your problem will fix mine too, so will stay tuned.
Old Jun 12, 2011 | 11:00 AM
mhuppertz's Avatar
A bad ground will cause that issue if I am reading it right. Make a new ground to the chassis to use with the relay mod.
RAW FUEL
Apr 25, 2006 11:01 PM
Tommy93w350
Dec 7, 2005 11:33 AM
winner172
Aug 19, 2005 08:22 AM
mazeppa
Feb 10, 2004 06:54 PM
rattle_rattle
Aug 1, 2003 11:26 PM
