head gasket time! ? about bolts/studs
Old 03-09-2007, 08:36 AM
cheapskate's Avatar
alright, my head gasket is leaking a little bit of coolant and oil around the exhaust side of # 5 cylinder. i think i will be replacing it with a standard head gasket from napa. my question is, should i reuse the old head bolts (provided that they are not stretched to far already), buy new bolts, or pony up some extra dough and get studs? if i was to buy new head bolts, is there a place on-line i could find them? i can't find them anywhere. as for studs- who has the best price? i have seen them for $425 somewhere. oh, i currently have a #6 plate, boost to around 30 lbs. max. i guess i will go ahead and fix the KDP with a TST kit while i've got the tools out.
Old 03-09-2007, 08:49 AM
NMCTD's Avatar
yeah get that kdp out of the way while your there. I would find a cummins dealer around there to get the gasket, and they have a guide that will show you if the bolts have stretched out of factory limits if they haven't reuse them. I wouldn't spring for studs unless you have alot of power planed for the truck in the future.
Old 03-09-2007, 08:59 AM
cheapskate's Avatar
no [I]plans[I]for anything crazy, maybe injectors/turbo/GSK/timing after i get a new tranny. I don't need anything over 325-350 hp.
Old 03-09-2007, 09:18 AM
NMCTD's Avatar
then I would just use the stockers unless they don't meet cummins specs anymore.
pwrtripls1
03-10-2011 12:12 PM
12valvetom
11-27-2009 11:37 PM
dieselboy59
01-30-2009 03:57 PM
smokewagon
08-08-2008 09:54 PM
Quick Reply: head gasket time! ? about bolts/studs
