HE351 install help
Old 06-10-2009, 05:24 PM
wyattearp29's Avatar
HE351 install help
I am rounding up all the parts for the turbo swap. I am wandering about the clamps for the cast elbow and exhaust. Are these the same clamp because the downpipe looks bigger. I need to get some ordered . So if any has an Idea let me know.
Old 06-10-2009, 06:22 PM
Big Blue24's Avatar
You can purchase both V-band exhaust clamps at the Dodge dealer for about 30 bucks each.
When you go to connect the exhaust, you will have to use a length of 3rd gen downpipe plus some 4" flex with two flat band clamps for the connections.
I have also seen guys make a hybrid down pipe where they cut off three inches of third gen downpipe and weld it to a slightly cut down 2nd gen downpipe.
When I did my swap, I had a 4" MBRP downpipe that was worth more than the cost of rounding up a used 3rd gen pipe+flex pipe+ band clamps so i did not create a hybrid 3rd gen/2nd gen down pipe.
Old 06-10-2009, 08:09 PM
Hey thanks for the info. I was looking at some on ebay but didn't know if they had to be the dodge issue. Are they same size or is the one on the down pipe bigger.
d22019
04-06-2011 10:34 PM
1stgenjake
10-07-2010 04:25 PM
ZacMan5712
12-19-2008 09:29 AM
WVAussie
01-15-2008 08:41 AM
Quick Reply: HE351 install help
