Gsk?
Old Aug 15, 2007 | 11:17 AM
DRam11's Avatar
Gsk?
Time to admit my ignorance. What is a GSK? I know it's something that can be a pain to install, requires care not to drop parts into the engine while installing, takes about two hours to install if nothing is dropped, has twelve springs, comes in 3K and 4K variations, and increases power. But what is it?
Thanks for alleviating my curiousity and ignorance.
DRam
Old Aug 15, 2007 | 11:21 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
GSK....Govenor Spring Kit...Helps to increase the RPM range from about 2600 to 3000RPM plus before de-fueling...Kit includes two springs.Not that bad to replace.
Old Aug 15, 2007 | 01:10 PM
ajoebob's Avatar
if you go with the 4k(4000rmp) or the 5k(5000rpm) you have to change the valve springs to HD(60psi) springs.
the 5k gsk is normaly only used in race trucks and takes a more engine work
Old Aug 15, 2007 | 02:02 PM
97DodgeRam's Avatar
One thing to add; w/o the GSK kit, the stock governor springs defuel around 2200 RPMs.
Old Aug 15, 2007 | 06:05 PM
DRam11's Avatar
Thanks. Very interesting. The information leads to other questions. Does moving the AFC forward affect the de-fueling point of the governor? Or does that affect another part of the fuel managment system? And, does installing a 3k GSK affect fuel mileage under normal driving? I ask because after moving my AFC forward the engine willingly revs to 3000 rpm when it used to reach only 2500 - 2600 rpm, and the mileage appears to have suffered somewhat when cruising down the road with no load on the truck.
Old Aug 15, 2007 | 08:01 PM
displacedtexan's Avatar
I can't comment on milage, as I owned my truck 5 days, and then did all the mods in my sig...
But the AFC is low boos fueling, off idle till about 6psi. It increases resposiveness, and smoke.
Old Aug 16, 2007 | 01:12 AM
wcbcruzer's Avatar
I wouldn't even think about a 5kgsk.
Old Aug 16, 2007 | 07:24 AM
Serious competition only. You would need bottom end work to run one...
Old Aug 16, 2007 | 06:13 PM
stirpicult's Avatar
ok, newbie question warning...
since this thread is up...this is my first diesel and first auto. do the GSK's change your shift points as well? mine truck shifts around 2000-2500 when i am on it right now. is this because it's defueling at 2200? so with the 3k, i will be shifting at 3000? or just have fuel until then and take care of my shift points on my own?
Old Aug 16, 2007 | 06:42 PM
It won't change your shift points. Mine did though
Old Aug 16, 2007 | 08:56 PM
stirpicult's Avatar
ok, so for us auto guys, how do we do that?
Old Aug 16, 2007 | 09:14 PM
IDK, have DTT or someone build you a VB to shift the way you want? I'm pretty ignorant on automatic transmissions.
siebertl
Jun 10, 2007 02:29 PM
SHARPMACHINE
Mar 6, 2007 08:45 AM
plow
Aug 9, 2005 04:25 PM
MR HYDROSEED
Mar 9, 2005 10:49 PM
Got Smoke?
Oct 26, 2004 03:57 PM
