Grid heater replacement gaskets
I had to remove my air intake & grid heater to get at my vacuum pump this weekend. The lower gasket on the grid heater tore & i am needing to replace it.
I just wanted to check with you guys that may have replaced these before to make sure I've got the right part. Is this the correct gasket for the 2nd gen's. I've got an 02'.
http://www.genosgarage.com/prodinfo.asp?number=3969988
that would be it. or there is this one also out there. you may be able to get one that would suit fine from napa or such. or local cummins dealer.
saw this one also
http://www.puredieselpower.com/catal...264e12bf8e10c5
saw this one also
saw this one also
saw this one also
saw this one also
saw this one also
I'm running a stock new one when I put a homemade airhorn on mine from cummins. havent had any problems with 40+ boost. the other materials I think would be just as good but more for higher boost applications. but I know alot of people running higher boost with the oem ones. could always find out who makes them for Oriely's and see what the material is and compare if your that worried.
jshaw214
04-29-2008 06:20 PM
6-Pack
01-28-2008 03:30 PM
