Govenor spring install help
Old Mar 30, 2003 | 09:31 AM
Jbolt001's Avatar
Looking at the top of the pump from the front the allen screw to the right is trapped under the throttle lever spring. Does the throttle lever have to come off the top of the pump to get this out or am I missing something?<br><br>Also is there a torque spec for the allen screws?<br><br>Thanks,<br><br>Jay
Old Mar 30, 2003 | 10:33 AM
jughead's Avatar
Re:Govenor spring install help
look farther down this page. but if you remove the lever be very careful it is indexed to the shaft. has to go back at the same place you removed it.
Old Mar 30, 2003 | 10:40 AM
Monty's Avatar
Could you just take a paint pen and mark the location of the throttle assembly on top of the pump to the VE housing? Then just make sure you line the marks up when going back with it?
Old Mar 30, 2003 | 12:04 PM
Old Smoky's Avatar
Hi Jay,<br>You don't have to remove the lever. You may have to cut out a small portion of the plastic tab that covers the screw though. A Dremel tool with a small cutter bit can easily take care of that. The spring can be pushed back while the screw is being removed. This will allow for sufficient clearance. Be careful when removing the top of the pump and governor spring. When removing the spring from the bottom part of the pump, be sure that the small spring, cup, and shaft, doesn’t fall into the pump, or on the floor. Also, be EXTREMELY careful to keep the parts clean. Clean the engine and pump before starting, and cover the open pump to keep dirt out. <br><br>Mike<br>
Old Mar 30, 2003 | 11:19 PM
Bushy's Avatar
Patron Saint of 1st gens
Ok, ok, ok...... the shop sent me an email on Fri afternoon..... my spring is in...<br>I'll pick it up this week...<br>Geeeezzz, some people are so hard to please.... ;D<br>BTW, have you got &quot;governor springs for dummies&quot; vers. 1.0 <br><br><br>Bob.
Old Mar 31, 2003 | 02:17 AM
Bushy's Avatar
BTW, for those who have done this mod I'd like to ask...
Had you made high idle adjustments prior to this install?
Did you &quot;reverse&quot; those adjustments?
Did you do high idle adjustments in addition to the gov. spring?
Did you experience any change/issues with idle quality/stability?
Can you think of any other mods that many of us do, that may need alteration or reversal of?
Thanks guys...
Bob.
Old Mar 31, 2003 | 07:50 AM
Jbolt001's Avatar
Thanks for the info.. I'll try it again next weekend when I have more time. <br><br>jughead- how is the shaft indexed? Inside the top nut of the throttle lever there is what looks like a slotted screw head inside. Is this the top of the shaft or some kind of set screw?<br><br>Thanks,<br><br>Jay
Old Mar 31, 2003 | 09:45 AM
jughead's Avatar
[quote author=Bushy link=board=9;threadid=12920;start=0#122407 date=1049098665]<br>BTW, for those who have done this mod I'd like to ask...<br><br>Had you made high idle adjustments prior to this install?<br><br>Did you &quot;reverse&quot; those adjustments?<br><br>Did you do high idle adjustments in addition to the gov. spring?<br><br>Did you experience any change/issues with idle quality/stability?<br><br>Can you think of any other mods that many of us do, that may need alteration or reversal of?<br><br>Thanks guys...<br><br>Bob.<br>[/quote]made high idle adjustments before gov spring not satisfactory. i did not change any adjustment after spring install. idle did not change at all. i still think high idle only changes unloaded rpm. the gov spring set-up on this pump looks like the gov. on my lawnmower. it is really simple. if you guys or gals have im service i am online all the time. if i am not here you can leave a message and i will get back to you. i dont claim to know it all but i can tell you what i have tryed and what worked and what didnt.
Old Mar 31, 2003 | 09:59 AM
jughead's Avatar
[quote author=Jbolt link=board=9;threadid=12920;start=0#122450 date=1049118618]<br>Thanks for the info.. I'll try it again next weekend when I have more time. <br><br>jughead- how is the shaft indexed? Inside the top nut of the throttle lever there is what looks like a slotted screw head inside. Is this the top of the shaft or some kind of set screw?<br><br>Thanks,<br><br>Jay<br>[/quote]the slot is in the top of the shaft.
Zackb911
13
Jul 28, 2006 10:40 AM
vinny
May 29, 2004 06:04 AM
darloa
Feb 12, 2004 09:52 PM
boehunter49
Dec 31, 2002 07:11 AM
