Glacier Diesel Pump Question
Old 10-09-2007, 07:23 PM
DieselBoy20's Avatar
If anyone has put a Glacier Diesel Mechanical Fuel Boss Pump in there truck, can you tell me what is involved with installing it and what things to watch for when I do? Also I forgot to ask if the setup came with a inline filtration system, tell me if it does or not....
Old 10-09-2007, 07:25 PM
Luvnacumns's Avatar
Use the search option in here andyou will get pages of reading... I can't help much mine's STILL sitting in the box!!!
Old 10-09-2007, 07:38 PM
I got lots of threads on the Walbro system which is the electronic system, but the one i ordered is the mechanical system that sits on the harmonic balancer and is belt driven off the crank...
Old 10-09-2007, 07:49 PM
Luvnacumns's Avatar
HUH... Haven't seen that one.>??? Soory no helpie there...
Old 10-09-2007, 08:09 PM
Can anyone add some input?
Old 10-10-2007, 12:46 AM
Someone has to have one of these in their truck by now? Riiggght....
Old 10-10-2007, 01:05 AM
Augusta's Avatar
Glacier Diesel's Mechanical Fuel Boss setup is essentially a clone of the Mitusa pump; if you search for "mitusa" you will be able to find more information.
Augusta
Old 10-10-2007, 06:51 AM
Mark1si's Avatar
I have a Fuel Boss and it is pretty easy to install alone. I did mine in maybe 4-5 hrs. I think the hardest part is trying to figure out where to run the lines from the pump to the frame. Yes it does have an inline fleetgaurd filter. It is really a nice system. You can set the PSI at what you need it to be. Idle psi is around 10-16 psi depending on fuel temp. You can goto http://www.glacierdieselpower.com/im...ss-Install.pdf and get the install instructions.
Old 10-11-2007, 09:52 PM
How many microns is the filter that comes with it?
wurkenman
08-15-2010 02:07 AM
bishkoff
05-16-2010 05:47 PM
ptgarcia
37
09-14-2006 01:13 PM
team
07-04-2006 11:39 AM
Quick Reply: Glacier Diesel Pump Question
