gauge illumination
Old Aug 3, 2008 | 03:06 PM
stroker101's Avatar
gauge illumination
just installed gauges (dash mounted). i looked at the thumb wheel that controls the dash brightness but couldn't figure which one to tap into.
can someone please help me? thanks in advance
Old Aug 3, 2008 | 03:23 PM
worldindustries's Avatar
try this
http://www.dieselmanor.com/diy/CMS3-gauge/G3image12.htm
Old Aug 3, 2008 | 04:10 PM
megacabdad's Avatar
Yeah. I pulled the panel off on the side of the dash, gives you easier access to the wires instead of laying on your back. There are two orange wires with brown traces. I pierced the wire with a test light, turned the head lights on, and turned the dimmer switch down. If you have the correct wire, your test light will dim with the switch.
Old Aug 3, 2008 | 04:16 PM
stroker101's Avatar
great info!!!!! thanks a million
Old Aug 3, 2008 | 05:08 PM
prattman's Avatar
The easiest way is just to use an add-a-circuit in you dash light fuse slot. Then you don't have to tap anything. Your gauge lights will dim with your dash lights.
http://www.bussmann.com/images/3c2dc...86ccd13aad.JPG You can get one at any auto parts store for $8.00.
Old Aug 3, 2008 | 05:47 PM
stroker101's Avatar
hmmmm? that is so kewl. thanks for another option.
Old Aug 4, 2008 | 07:30 AM
Moobesor's Avatar
which fuse slot # is it? I'm a simpleton.
Old Aug 6, 2008 | 05:24 AM
prattman's Avatar
Pop the cover on the side of the dash. It should say which is the dash light fuse on the diagram inside the cover.
schamran
Feb 11, 2013 08:14 PM
scuzman00
Dec 9, 2007 08:10 PM
PZM123
Apr 15, 2006 09:32 AM
js
Jan 19, 2003 09:46 AM
