View Poll Results: Which Spray is the Best? (Pick Your Poison)
Propane
13.73%
Nitrous
19.61%
Water Meth
39.22%
Don't Worry Bout Trying to Decide, Just Take OUt a Second Mortgage and Get All Three!!!
27.45%
Voters: 51. You may not vote on this poll
What Gas Should I Choose???
Old Sep 4, 2006 | 04:21 AM
streetsmoker's Avatar
Cant really decide here, so I'm just wondering. Propane I know is the hardest to install, but other than that I don't know much as to the pros and cons of each system. Other than Nitrous makes for high head pressures.
I got money to spend, but don't want to waste it. Or have to change anything if possible on the engine. This is my next logical step as I don't want the investment it takes to run all fuel and the modded CP3 it takes to run on strictly #2.
Old Sep 4, 2006 | 05:05 AM
dogger's Avatar
Nitrous you are asking for problems without installing new head studs. I can spend your money and believe me I will get good value for your money on my truck!!
L8r,..............dogger
Old Sep 4, 2006 | 06:11 AM
Duallydog's Avatar
I'd say propane and water/meth.
Old Sep 4, 2006 | 07:27 AM
CIN'S DODGE's Avatar
Mrs. missin on a mission & keeper of the can
Streetsmoker,there is a write up on propane injection pros and cons in Diesel Power March 2006 edition. Thought this might help you decide.Cin
Old Sep 4, 2006 | 07:39 AM
pullin hard's Avatar
the way i see it, Nos, is expensive, and you have to keep getting your bottle filled, it don't last long. will need to upgrade the heads/bolts.
pain in the.....
propane, good value,more mileage, pretty safe, need a large enough tank to make worth while, now ytou taking up bed space, or under truck tanks, there again, you need to refill often, finding places that will fill on off hours etc, another pain in the .....
water/meth, roughly a little cheaper, fairly safe,washer fluid is like 1-2 bucks a jug, can get any hours of the day, can fill any time of the day/night,you will always have lots on hand, so you will never have to worry about a dirty windshield, if you have power adders, then temps should come down, maybe some added power.
i haven't done any of these, but plan on the water/meth combo soon, just makes more sense for me.hope this helps
Old Sep 4, 2006 | 05:51 PM
Yeh, I was wondering at my power level if I would still get a power increase from water meth @ a 50/50 mix? My temps are fine now with the bigger turbo, so wouldn't I be able to run a richer mixture than the 50/50 washer mix? If so, where and how do you get pure methane alcohol?
Old Sep 4, 2006 | 05:55 PM
acook's Avatar
Propanes for barbecues, nos or water meth...
Old Sep 4, 2006 | 11:58 PM
XLR8R's Avatar
Don't y'all have some extra corn licker stashed about?
Old Sep 5, 2006 | 01:05 AM
You are thinking of ethanol alchohol. Not methanol. Don't exactly know the difference though. So what is the average power increase people see with these water meth kits? Looks like that is the spray I'm gonna go with.
Old Sep 5, 2006 | 01:31 AM
XLR8R's Avatar
ethanol = grain alchohol (yummy!), has higher energy content
methanol = wood alchohol (poison), lower energy content, cheaper
corn likker tastes better, works great
Old Sep 5, 2006 | 01:49 AM
So they are interchangeable? If so cool! I know a few moonshiners around abouts. I guess you could use some cheep 100proof vodka then right? Cause it's not too fit to drink thats for sure. That would be a 50/50 mix!!!! LOL!
Old Sep 5, 2006 | 01:59 AM
XLR8R's Avatar
They're both fine for your truck - just don't try drinking both
'Shine is the way to go, especially in your neck of the woods, but I wouldn't waste even cheep vodka in your cummins - it works too well on chigger bites for that!
Old Sep 5, 2006 | 08:38 AM
judge88's Avatar
i have tried both and nos is what i use now. i run 58lbs of boost without it and into the 60's with it. never had a hg issue. i am studded however. nos gives me the best power by a mile over water meth and cools my egts alot better.its alittle more money for nos with getting the bottles filled but it makes up for it when you hit that little red button .water meth is a hg killer just like nos also. both can hurt you if not prepared for it and if its not used correctly.
Old Sep 5, 2006 | 02:18 PM
Goggleyed's Avatar
Are you using BullyDog's nos kit?
Old Sep 5, 2006 | 02:55 PM
judge88's Avatar
no, but i did look at it. a little bit more $ than i wanted to spend. i have the nos kit from jegs. its made for diesels and works great. $499 is the price i think.
