fueling problem
fueling problem
Ok, Mods in my sig
After I gutted my afc my truck smoked pretty good when I wanted it to. About a week and a half ago I put a bottle of diesel 911 in the tank when I fueled up since its getting cold. Now after another fuel up my truck won't smoke at all, not even if I lug it. Also, my turbo take a bit longer to fire which is weird since it is a stock turbo with the wastegate blocked. Also the DV holder for cylinder #3 is wet, is it time to rebuild my pump? Not sure what else it could be. Thanks for any help.
Never use 911 except in an emergency after your fuel has already gelled.
That's why it's called 911.
911 is mainly alcohol which dries out your fuel destroying the lubrication qualities of the diesel.
Bad for your injection pump.
Use the Power Service in the white jug for winter anti-gel.
so I changed the fuel filter and put on the correct fleetguard filter. As I was fighting with my filter and mount and thinking about how bad I wanted to beat the smart out of whatever engineer decided to put the fuel filter right there, I noticed that my cut off solinoid shaft was crooked. So, I pulled that off, put a spring on there to keep tension on it in the open position and fired it up. Full power boost and smoke! I am thinkin that the shaft wasn't opening the valve all the way so I was running on a half open fuel supply valve. Now I need to replace the o-rings on my dv holders and I won't have to do anymore service type stuff to my pump. Any idea where to get o-rings for this? I have heard guys say they are a Bosch direct part, anyone know for sure?
On trucks with vacuum assisted brakes remove the two nuts that hold the master cylinder to the booster.
Even though it doesn't look like it you can now swing the entire master towards the fender without removing or bending any lines.
Gives you more than enough room.
Guys,Guys..and Gals.. Use a 90% oil filter wrench. There are one's that take a socket extension. Slip it on, pop the extension in and turn toward the front and the fuel filter come off... But.. I would like to yank the whole dam thing off the engine and relocate the fuel filter bracket and lines. Anyone done this??
Sounds like you don't know the trick that makes it 500% easier.
Man oh man oh man... thanks Bill! I recently had my fuel filter decide to clog up on a trip... luckily it was in the daylight and I was carrying a spare filter. Still it always takes a bit of wrassling and contorting to get the darn thing off. NEXT TIME I'll be prepared!
