Fuel Tank Module/Sending unit
Old Jul 7, 2007 | 10:00 PM
12ValverDave's Avatar
I have an air leak and have narrowed it down to the fuel tank module/sending unit. The Two connections coming out of mine are severly rusted and I have a good idea that is causing problems, is there anyway to repair those lines, such as replacement. My only option for replacement now is the dealership who wants $330 dollars for one. No parts stores around can get it for the diesel and i see them online on ebay all the time for 100 dollars however they are for a 98 and newer truck but it says the wiring connector needs to be modified. Any suggestions are appreciated.
Old Jul 8, 2007 | 06:39 AM
97' CTD's Avatar
try http://rockauto.com/, this is where I got mine
Brandon
Old Jul 9, 2007 | 07:34 AM
Do you have any idea how much it you paid for that part from them? and also was your sending unit messing up or did you have an air leak like in my case?
Thanks,
Dave
Old Jul 9, 2007 | 09:47 AM
infidel's Avatar
The dealer sells rebuilt modules for around $125
Old Jul 9, 2007 | 12:26 PM
The dealer near me said they couldnt get the rebuilt ones anymore? Id pay 125 bucks in a heartbeat, rebuilt or not
Old Jul 9, 2007 | 04:53 PM
97' CTD's Avatar
Mine was sucking air at the metal elbows. I did away with those quick disconnect jobs and just ran rubber. I paid around or a little less than 300$ but it was a brand new CARTER unit and it is working great!
Brandon
Old Jul 10, 2007 | 10:33 AM
spyder3634's Avatar
do a search for vulcan draw straw...i replace my elbows with it, 50 bucks and it was worth every penny
Old Jul 15, 2007 | 03:56 PM
vulcan draw straw says its only for 98 and newer trucks, can it still be used on a 97 truck or does anyone know?
Old Jul 15, 2007 | 04:04 PM
Here is my signature also:
Old Jul 16, 2007 | 08:40 PM
dieseldemon's Avatar
The only diff between the 97 and 98 12 valve Mod is the sender diff OHMS
the 98 sender will not work on the 97 the rest of the mod is the same
tigafila
Apr 25, 2007 06:50 PM
chris s
Mar 6, 2007 05:32 PM
Bobcat698
Aug 23, 2005 09:57 AM
niekrewb
Jul 26, 2005 01:52 AM
SmokinFive9 4x4
Dec 22, 2004 10:01 AM
