Fuel Rail Volume
Old 09-02-2009, 10:04 PM
Aggie007's Avatar
Fuel Rail Volume
Would having a fuel rail with large volume benefit the dual CP3 users with larger injectors? I was looking at one earlier and they would be easy to machine, I just need to figure out what material to use.
Old 09-02-2009, 10:06 PM
cbrahs's Avatar
then you are limited to injector line size. it would be cool to have a larger rail and oversized lines similar to the 12 valve guys with bigger lines
Old 09-03-2009, 03:19 AM
homewrecker's Avatar
And then the feed tube and the injector inlet becomes the next restriction.Modded factory rails are an option but I haven't seen any dyno testing to prove if they work or not.As far as I know all the big hp guys(Tim Barber,Lloyd Mills etc....) are using a stock rail.
There was a big debate also about whether or not the inside of the rail had some sort of coating to minimize erosion(etching) from the high fuel pressure CR 's see.Don't know if that debate was ever settled.
Old 09-03-2009, 11:51 AM
XLR8R's Avatar
Well, the coating is invisible, and wasn't adversely affected by the powder coater's oven.
Old 09-03-2009, 12:33 PM
I saw the pic of your rail, yellow right? Is yours modded? I ran one for a few months and didn't notice much,maybe a little on the bottom but that was along time ago,long before I got half whats done to the truck now.I just don't see them doing much good.If you are maintaining RP,especially with dual or modded pumps, I can't see where they would help.
Old 09-03-2009, 01:43 PM
XLR8R's Avatar
Yep - it's yellow so I can see where to connect the propylene oxide line at night.
Modded rails can't hurt anything except your wallet, and are a step in the right direction - but I think they only make sense for max-effort mills.
Old 09-03-2009, 02:46 PM
cquestad's Avatar
Loss of pressure is what kills hp...a bigger rail won't do squat...unless everything is bigger.
Old 09-05-2009, 08:23 PM
Aggie007's Avatar
Thanks for the replies. I think this will be on the back burner till I can look more into it.
Old 09-05-2009, 08:54 PM
no_6_oh_no's Avatar
Pretty much. About the only effect, and for the most part a good one, is they tend to lessen the hammering the injectors take from the pressure spikes.
D2 Cat
09-14-2009 05:37 PM
PaulDaisy
02-19-2007 09:53 AM
HL649
05-22-2005 02:13 PM
Mopar1973man
04-26-2005 07:57 PM
shortround
03-27-2004 08:00 AM
Quick Reply: Fuel Rail Volume
