Fuel pressure goes back and forth under steady load
Old Feb 15, 2007 | 12:43 AM
blueberry's Avatar
With my fuel pressure gauge, I noticed something I don't understand. When I am climing a grade in 5th gear and WOT, with 13 psi of boost, the fuel pressure gauage will go between 5 psi and then a few seconds later go to 2 psi, then go back to 5 psi, etc. During this time the boost remains constant. Can someone explain?
Brian
Old Feb 15, 2007 | 06:28 AM
G1625S's Avatar
Where is the sending unit for the gauge? Sounds like air (I know, not again...) or a lousy lift pump or a crappy fuel filter. Aside from that, maybe the vane pump in the IP or the pressure control valve associated with it is doing some weird things...Dave, where are you?!
Old Feb 15, 2007 | 09:11 AM
blueberry's Avatar
I use a Westach electrical fuel pressure gauge. I have a hollowed out banjo bolt for the line that goes to the injection pump. A 45 elbow is threaded into that, and the sending unit threads into the elbow. Connections are sealed with Permatex #2 no leaks there. The fuel filter is a Fleetguard FS1232 that I changed on Sunday.
Is there a chance these fuel pressure readings are consistent with a collapsing fuel line? Now that I have less air in the system, there should be more suction forces on the rubber line to the tank and the line might actually collapse. Before I think I may have been sucking air from the treads on the lift pump quick disconnect fitting. Two days ago I replaced it with a barbed fitting and sealed the threads with Permatex #2.
Brian
Old Feb 15, 2007 | 09:20 AM
Ace's Avatar
Ace
I think it would take alot more suction than any lift pump could generate to collapse even a rubber fuel line.
Old Feb 15, 2007 | 07:03 PM
That's an odd one. I never saw the gauge fluctuate at a constant load. There's gotta be something up with the injection pump on this truck.
I'm with Ace, unless there is a blockage you are not gonna suck the line shut. If my Walbro isn't sucking 3/8" fuel hose shut a diaphragm lift pump sure isn't going to.
Old Feb 26, 2007 | 04:40 PM
mooktank's Avatar
My gauge is the same one and it does similar things. I wonder if the sending units are too sensitive.
mck46
Mar 8, 2013 02:15 PM
southerngal
Jan 10, 2007 08:37 PM
JARHEAD
Dec 19, 2004 04:57 PM
